How do I connect it right? I'm having problems in connecting cables from the mixer to the amplifier
    Brigadier General:
  • 8,546 Answers
A generic question will get a generic answer.
It would go into a typical Tape Monitor loop on an integrated amp or receiver. In's to Out's. If we're talking about a power amp, the mixer would go between your sources and it.
Posted on Aug 05, 2010
Mixer to P.A. system connection
You'll want to use the Stereo Out connections at the top right. You might need adapters to plug into whatever system you're trying to use. Also note that this mixer does not provide power, so the speakers you're using have to be self-powered or be driven by a separate amplifier. You would then plug the Stereo Out connections into the INPUTs of the amplifier.
Jun 28, 2013 | Nady Systems Nady SRM-10X 10-Input Mixer
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    How to hook up speakers? Sound sounds muffled
    You DON'T connect speakers to this... this is NOT a powered mixer... you MUST use external amplifier !!!! You use bvalanced (TRS) cables to a suitable power amplifier which connects to speakers. Some Behringer mixers such as the PMP5000 have built in amplifiers to drive speakers... yours does not.
    Jul 23, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
    How to in install the speakers to it
    You will need either powered speakers or an amplifier for the speakers. If you have powered speakers with built in amplifiers, use balanced audio connection cables from the MAIN outs of the mixer to the speakers, Use XLR or 1/4 inch TRS cables.
    If you do NOT have powered speakers you will need amplifier as well and speaker cables in addition to the audio connection cables above.
    Dec 29, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
    I received the turntables and mixer but Im having trouble installing everything together. Is there any companies that can help you install the turntables, mixer, and speakers
    Not to worry if you can take some pains and be confident. First of all arrange the turntable, the mixer, the amplifiers and the speakers. Connect the turntables two RCA pins to the PHONE pins L and R. of the mixer. Using another set of RCA cables to connect the output of the mixer to the amplifier's AUX inout L and R. Try to connect the red and white in accordance to the L&R. The speakers should be cconnected to the left and right of the amplifier's main. if you have front and rear use them but connect with the polarity of the red and black polarity . Use a good power supply multipin unit to connect all the power. Do not switch on until you have checked once again. Now switch on and play your favourite record. DO take time to do and you will suceed. Good day
    Jul 11, 2010 | Stanton ST-150 Turntable
    Hello, I am trying to plug my Mixer into my amp but only one speaker has sound..I am using a Rane ttm57sl mixer with technics turntables & cambridge audio azur 640a amp...I've gone from the Aux out on...
    Why don't you try using the main outputs (the 2 XLR connectors). With 2 cables connect these two (left - right) outputs at your amplifier's aux in. In that case take care that the "output level" of the mixer works like master volume controlfor the signal that the mixer sends to the amplifier.
    In case of a problem or clarification, don't hesitate to post.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    Feb 04, 2010 | Cambridge Audio Azur 640A Amplifier
    Connection
    There are 2 ways to have an EQ in the system. If the mixer (1204) has inserts for the mains, you can use a set of insert cables to connect the EQ. If not, connect the Output of the mixer to the Input of the EQ and the Output of the EQ to the Input of the Amp.
    The insert cables will allow you to electrically connect the EQ as described above only using a single set of cables. These cables are 1/4" balanced or stereo at one end (Tip-Ring-Sleeve) and dual XLR at the other. You will need 2 insert cables, one for right and one for left.
    Hope this helps,
    dan
    Jun 19, 2008 | Audio Players & Recorders
    Very low volume!
    If you're used to playing your vinyl through a hi-fi turntable (and not DJ turntables) then you're probably used to your turntable having a built-in amplifier. DJ decks don't have these and if you plug into 'line' it will come out very quiet. Try plugging into 'phono' if you have it, if not you'll need some extra amplification somewhere between the deck and the speakers (a mixer usually takes care of some of this before it goes into the main amp of the system). Hope this helps. Ad
    Aug 06, 2007 | Sony PS-LX350H Turntable
    32 people viewed this question
     Grubhead
    Grubhead
