Need a manual for a Bryant heating cooling system. Model number CK5BXAOZ4014AAAA. Cant find on the website. And where are the fuses located on the system??? Serial Number 3302X40069
  • 396 Answers
Model numbers for Bryant AC difference between a model pa4zna048 & a rspma48
The difference is the sticker on the outside of the unit and the slightly higher price for parts on the Bryant. Go with the Rheem but don't be mad at me when it breaks down, the Bryant will too. Honestly it's luck!!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 30, 2017 | Bryant Heating & Cooling
Is there an extended warranty on Bryant model number 126A air conditioner installed July of 2010?
Typically these machines come with a 10 year parts warranty. Provided it was registered by the installer and you are the original owner. If you are not the original owner TYPICALLY that drops your part warranty to 5 years. Conpressor may still have 10. Extended warranties generally mean your warranty is for PARTS AND LABOR. I have seen where customers do not buy the extended warranty AT TIME OF PURCHASE but do purchase this at a later date, obviously at an increased rate. You can contact the manufacturer WITH COMPLETE MODEL AND SERIAL NUMBERS OF BOTH INDOOR AND OUTDOOR UNITS and they will be able to give you the information you need.
Aug 19, 2017 | Bryant Heating & Cooling
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
May 04, 2017 | Bryant Heating & Cooling
Where are the schematic for Bryant heating condenser model #986TB ?
most schematics are found on the inside panel where components are located
Jan 12, 2017 | Bryant Heating & Cooling
Need the fuse number and location for heated/cooled seats 2003 lincoln navigator
The fuse for the driver & passenger climate control heat module is located in the fuse panel inside the vehilcle. It is located in the number 118 position (see picture of layout below) and should be a green "maxi" fuse. This should be in your owners manual if you have one. If you do not have one and would like a copy, you can email me at csautomotivecars@att.net with the make, model, year and what you are needing and I will be happy to email you a copy. Don't worry no cost. Anyway, I hope this helps you and good luck.
Apr 21, 2011 | Lincoln Navigator Cars & Trucks
I am trouble shooting a Bryant Hi-bred system that uses an air cooled heat pump with high efficiency gas furnace for backup and low ambient operation. How does the system decide whether to use the air...
Your t-stat should be set up so that the furnace is the second stage heat and also emergency heat. First stage (heat Pump comes on) sometimes they use Time to start 2nd stage, sometimes they use outdoor temp and this all bepends how bryant has set it up, without a model # I cannot tell you but send it and i will look in somebooks i have to tell you.
Mar 01, 2011 | Bryant Heating & Cooling
I am trying to replace my old bryant heat pump with a new bryant heat pump, but I am having a difficult time figuring out the tonage. Can you tell me if I have the model number?
yes just post the model number and someone will be glad to help you..
fyi if the model number has for example 373036 373042 373048
the o and number after it usually is the btu value...
12000 btu's = 1 ton so a 036 would be a 3 ton 042 3 1/2 060 would be a 5 ton
post the number someone will help you out... another way to find out
carrier which makes bryant units can help you also
a number for ft. worth location is 817-834-4496 good luck to you
Feb 10, 2011 | Heating & Cooling
I am replacing a four year old Bryant thermostat (7 wire) that runs a Bryant heat pump and gas furnace. I connected the Honeywell EIM to the old wires using the same colort codes: W = W (o/b); Orange =...
Well you are naming 6 colors, where is 7?? I'm guessing you don't have a constant 24 going to the heat pump and there is no transformer outside. Send model number of indoor and outdoor, double check your wiring, double check your setup.
Aug 13, 2017 | Heating & Cooling
Manual for model no. 234c 5pw bryant boiler
I have a bryant boiler in my home and been having a plumbing co work on it since spring and they replaced the 3 speed pump with a single speed now cant get it to push air out of system
Nov 08, 2010 | Bryant Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
Heating & Cooling Logo
782 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
