REMOVAL OF TV STAND BAIRD 42" LCD TV HAVING PLACED ON WALL CANNOT REMOVE STAND
    Sergeant:
  • 252 Answers
Look carefully some sets have buit in snaps that you have to unsnap in addition to tiny screws
Posted on Aug 05, 2010
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
I CAN NOT REMOVE STAND TO PLACE TV ON WALL
Download the user manual to this set. It will have all details. To download it, click here.
Jul 04, 2012 | Sanyo 42 in. LCD TV
I have a 42 in. Vizio Galleria and need to remove table top stand so I can wall mount. How do I remove base stand?
1. Unplug all of the cables and cords from your GV42L FHDTV10A.
2. Place the GV42L FHDTV10A face down on a soft and flat surface (blanket, foam, cloth, etc) to prevent any damage to the TV.
3. Pull the stand cover off by squeezing the sides to release the retaining plastic tabs.
(This is probably the trickiest part to find this, just feel around and don't be too rough with the plastic)
4. Remove the four (4) screws (screw's specs: M4, 0.7 Pitch, 15mm long) so that the stand base can be removed.
5. Gently remove the stand base
6. Now, the GV42L FHDTV10A can fit securely to a mount (sold separately) by utilizing the mounting holes in the center of the back panel of the TV. Please make sure to read the instructions of your specific mount to properly hang the GV42L FHDTV10A
Mar 13, 2011 | Vizio Gallevia GV42LF 42 in. LCD...
I need to download a users manual for a Baird 42" tv lcd
Try the following sites for the users manual
tv.manualsonline.com/ex/product/headline/.../Baird/.../PR42BAIRD www.user-guides.co.uk/.../baird/baird42/baird-42-inch-tv-online-manual.html
May 03, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
42'' Sense LCD TV Removing the Stand
THE WAY I DO IT FOR ALL TV
usually you got 4 screw in the back of the tv need the bottom
be sure to put tv face down on your bed you gone have a surprise
gone fall from the stand
and pull it from the tv by the buttom
Mar 06, 2010 | Televison & Video
42LH3000 LG LCD TV
SOME TV'S HAVE A PANEL TO ACCESS THE A/V CABLES...I.E. HDMI,S-VIDEO,COMPONENT,ECT. IF YOURS IS THE CASE LOOK WHEN YOU REMOVE THE PANEL AND SEE IF THERE ARE ANY COVERS THAT NEED TO BE REMOVED SO YOUR STAND CAN SLIDE INTO PLACE.
Feb 20, 2010 | Televison & Video
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Stand base removal
how do you remove the stand of lg 50pg30fd so it can be wall mounted
Jun 15, 2008 | Toshiba 42HP66 42 in. LCD Television
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Stand
You should see at least 4 large phillips head or box headed screws tha hold the stand in place.
Mar 10, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Televison & Video Logo
340 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
