Question about Refrigerators
GE Profile 22 model French doors.Where French doors open there is a clip on both doors that snap into the center of the door. The clip is broken.This is th second time this has happened.TRhe first time on the right door. There replaced the whole right door as it as easier than doing just the clip.Is there a parts picture of this and also instructions for it. I went on line and they told me it is part @WR24X10173 abd the cost is $173.00 and they call it a door gasket assembly. I find this hard to believe
  • Anonymous Feb 26, 2009
    My GE Profile 22 french door model is still under warranty (I've owned it 11 months) and I've had to have the door gasket replaced twice! The gasket on the left door when opening "grabs" the gasket on the right door and over time rips it. Poor design!
  • Anonymous Apr 23, 2009
    I have the same issue. Can I replace just the little clip? I can't figure out how to remove the gasket to access the clip.
    Genius:
  • 1,073 Answers
Go to www. apwagner .com you can create a user name and password to look at the exploded view of the ref the retail cost is 190.00 something on the part plus tax and shipping
Posted on Apr 26, 2008
How do I replace parts on the door of the GE Profile Advantium 120 Microwave
the door will come apart so you can screw it in from the inside its pretty easy just lay it out so you dont lose parts same with the clips they shoud either snap in when you have door apart or screw it in its just time consuming and terious work buy its do able
May 01, 2012 | GE Profile Advantium 120 Wall Oven
How to change the door gasket o a GE Profile French door refrigerator. The clip at the top is broken and it is part of the gasket. Not a very robust design.
MAKE SURE THAT YOU DO NOT USE TOO MUCH PRESSURE ON THE DOOR LINER, AS IT IS FRAGILE, AND HARD TO GET AND DIFFICULT TO INSTALL. JUST WORK YOUR WAY AROUND WITH GASKET SLOWLY, AND ONCE IT IS SECURED THEN CAREFULLY USE A HAIR DRYER TO REMOVE ALL CREASES AND ROUGH CONTACT EDGES ON GASKET AND LIGHTLY SECURE THE GASKET AS THE LINER IS PLASTIC/PVC. IF UNSURE GET A PROFESSIONAL TO INSTALL.
Feb 26, 2010 | GE Profile PFS22MBS Bottom Freezer French...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Display out
Does the display not light up when you press a button ?? Check the electrical connector at the bottom of the door as it may have corroded or become disconnected.
Sep 01, 2008 | GE Profile PFS22 33" Artica French Door...
Ge profile artica side by side refrig
is it the type of doors with the plastic snap on caps that cover the hinges, if so pop them off and unscrew, if it has an ice maker on the door its more complex, good luck
Mar 13, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Door Latch
Larry, I believe you have to remove the inside door frame cover, starting at the top and working your way down. The cover should snap out and away from the door. Next would be the gasket bracket clips. With a flat tip screw driver insert into the seam between the gasket bracket and the door frame and pry out until the clips snap out. Then proceed to remove the gasket from the channel. Catriver.
Jun 13, 2007 | LG LRFD25850 French Door Refrigerator
Refrigerators Logo
433 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
