Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been replaced.
Sounds like either it's low on oil or the oil pressure switch is bad.
Posted on Aug 28, 2010
My welder revs up but wont put out full power
We need a better description of what is happening. I see many engine driven welders that when loaded up heavily the engine rpm drops because of needing a tune up or complete engine overhaul. Since the engine can't run at designed r.p.m. the welder won't put out "full power" With a better description of problem, Such as engine is not slowing down but will only weld at 100 amps experts here could help you better.
Sep 18, 2014 | Lincoln Ranger 8 8000 Watt Kohler Gas...
Engin boggs down while welding
have you had the cables tested,welding weares them out.how old are they a welder is like a big old coil or armature the contact points on it gets corroded causing it to work harder causing your bog
Apr 08, 2012 | Miller Trailblazer 302 Welder Generator...
Engine oil leaks out the gasket between cases how will i repair
Two options here:
1) The one i will suggest... send it to an authorized repair shop. Check with your local welding shop/store (Praxair has direct connection with the anywhere), they will ship it down to an authorized dealer.
2) If you are a mechanic or know how to change head gaskets, then take model and serial number of your engine (p.e.Kohler, onan or honda) and go to a autoparts shop and ask for the gasket, then just replace it.
Feb 06, 2011 | Lincoln Ranger 305g Welder Generator...
Welding fine , then machine quit welding, would still rev up, but barely arch!
I had the same problem except it was with a miller welder. it was a bad ground connection on the ground cable. if you have an ohm meter. turn off your machine,but do not unplug it. check for resistance from chassis ground on machine to input ground if your input on the machine is good you may have a bad cable,input connection or the ground clamp may not be making a good connection to the cable. good luck!
Dec 21, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My lincoln welder/generator with onan engine will only run for a short time when it shuts down. It doesn't matter if in use or not, either welding or generating. It is getting fuel and the coil has been...
The engine has low oil level shutdown. It may be the reason for stopping.
Use the welder only at level condition. Check the oil level, before every start.
If no result, find and check the oil sensor contact (if possible replace with good to check). Try with disconnected and shortened contact prior to buying a new one.
Other possible reasons you already checked
Aug 05, 2010 | Lincoln Electric Ranger Gxt 250 Amp...
My lincoln ranger 250 no weld output
sounds like the transformer winddings which generate the amperage for the arc are breaking down
Jul 03, 2010 | Lincoln Welding Tools
Lincoln Welder Generator Oil Question
Better late then never! im-308 total lube oil is 4 pints for a briggs and stratton engine
and 3.5 for an onan engine with filter change.
Note: an internal kill switch will shut down the engine if the oil level drops below a minumum
operating level on the onan engine only.
on your welder use a multi-viscosity sae sj grade or better oil. recommended is 10w-30.
if you work in cold environments use 5w-30 oil , it's thinner and will flow easier
during cold starts. Synthetic oil is better. just more expensive. change oil at least
every 100 hours for better performance. good luck!
Aug 19, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
my 20 hp onan won't start it's getting fuel and spark. it will fire and almost run then stop. and a few times poped back through the carb. it has good compresson .and the flywheel key has been replaced
Apr 13, 2009 | Lincoln Electric Ranger Gxt 250 Amp...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
400 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
