Question about HP Officejet 7210 All-In-One InkJet Printer
HP 7210 All in one Printer Cartridge replacement problem
My husband took out the used black ink cartridge # 96 before I got home with the replacement #94 per the manual should fit. I've watched the HP support video twice and there is no way to slide the cartridge in as shown because it is not a pure rectangle shape, there is an extension sticking out on bottom side where copper contact points are. Have read the manual, watched the video, shoved at it and it is not going in. Is there a trick or some lever to lift to get it to go in? Print cartridge access door does not lift up high enough to fit #94 under it and #94 is smaller than #96
Comment by fizzydp, posted on Apr 26, 2008 Notes back on fix suggestion: textures on sides of cartridges are identical but it doesn't matter because neither "slide in" because of the white plastic guide slots on sides of both color and B&W cartridges that have prongs sticking out that make it impossible to slide them in.
  • fizzydp May 10, 2008
    the we bought cartridge did actually fit. My neighbor, a dental surgeon, came over and finally got the thing in by turning the power on and off until there was enouogh space to slide it in
    Problem Solver:
  • 12 Answers
What you need to do is to get the cartridge no HP0339. You can get it from Amazon.co.uk for 7.99 or from pc world
Thanks
Subha
Posted on May 09, 2008
I have an HP Officejet 7210 All-in-One. I would like to know if there is any way to print a document that only needs black ink, even though a message always pops out that I have to remove and check the...
Hi
Black is not True black. It is slightly brown.
Printing in black uses mainly black but may also a tiny amount of a mixture of some of the other colours.
To minimize the usage of other colours:
HP Solution Center > Settings > Print Settings > Printer Settings > Color > tick Black Print Cartridge Only > OK.
HP ink can be expensive. It is possible to economize on HP inks in some cartridge formats by using Ink refill kits.
I hope this helps.
Aug 24, 2011 | HP Officejet 7210 All-In-One InkJet...
Am having difficulty removing Black (96) print cartridge from an HP 7210 All-in-one printer/scanner to enable installation of a new (96) cartridge and need help!
on the software on your PC there was a option in the printer setting>> preferencess>> maintenance, which you can select the ink/cartridge replacement..
Jun 25, 2008 | Office Equipment & Supplies
The printer says that the black ink cartridge is bad. Replace
Please use HP 94 or HP 96 black ink cartridge.
Regards,
Rizwan.
Mar 01, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Replaced black ink cartridge while printer was off - broke printe
Is the black case broken?Do you try with another black cartridge?If not, try it.You can't put color cartridge in black case.There is an option to replace all carriage unit.Please contact service in your area.
Nov 01, 2009 | HP Officejet 7210 All-In-One InkJet...
Black cartridge is not being recognized, amber light blinking
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Nov 10, 2008 | HP Officejet 7210 All-In-One InkJet...
Replacing black inkjet cartridge
are you trying to change the cartridges while the printer power is in the ON position? If not, plug the printer in and open the cartridge cover and the bottom bar should move down and then open the top cover over each ink cartridge and pull the ink cartridge toward you.
Good luck
Aug 02, 2008 | HP Officejet 7210 All-In-One InkJet...
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
HP Officejet 7210 All-in-One Leaking Ink
the ink collector(well) hav accumulated much ink overtime its due to be serviced.remove the cartridges move the carriage to the middle remove the ink collector pad and clean , clean the collector with methylspirit check for the sensor beside and clean if blocked
Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
HP 7210 All in one - cannot get new black in cartridge
Check to see if the old one slides in as rough as the new one.
Apr 24, 2008 | HP Officejet 7210 All-In-One InkJet...
HP 7410
Sounds like a bad cartridge, you may want to try an original, it may be worth the cost instead of a new printer. First clean contacts on printer w/alcohool and put the cartridge back in. Not fixed try a new one may be worth the $40
Oct 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
156 people viewed this question
Ben Johnson
