Question about Saniflo & Saniplus& Macerator Pump
Our macerater was working fine up until yesterday ,,then we here a slow grinding noise coming from it ,,it is still working ,but instead of hearing a short noise we now have a long grinding noise from the macerater
    Scholar:
  • Saniflo Expert
  • 115 Answers
Could be something stuck on the blade or the impeller. Also the pump cover plate may be obstructed. Also inspect the discharge pipe for clogs.
Posted on Aug 11, 2010
Flapping Noise Coming from Engine
lift the hood ans check fro a drive belt that is coming apart
Feb 10, 2018 | Cars & Trucks
Just changed timing belt on 2001 nissan xterra. I can hear a noise coming from intake cam and slight rubbing or grinding noise for distributor cap. Does this mean timing is off or belt is too loose /t
some of those distributors were pretty loud as far as rattle noise. could be distributor it self, but would not worry about it much until it actually completely dies. could run like this for long time.
Aug 20, 2017 | 2001 Nissan Xterra
Grinding rear my 99 dodge durango
What brake you have,maybe need to be change.
Feb 26, 2013 | Cars & Trucks
Front driverside tire hesitates when the vehicle starts moving
Sounds like you have a bad wheel bearing. These cars are known for that. It could also be a bad CV joint [axle] , but it won't usually make your wheel hop. Jack car up and try to move wheel top to bottom. There should be no play at all. Try spinning the wheel while it is off the ground, if it's a bearing, you will hear a grinding noise. If it's a bad CV joint, you will hear a clicking. Let me know if this was helpful to you, and until you get it looked at, I wouldn't drive it, as the wheel can fall right off if it's a bearing. Good luck
Jan 04, 2013 | 1997 Chevrolet Cavalier
Low grinding noise from front axle when stopping my 86 Chevy k5 blazer
Check your wheel berrings by jacking up the frount of the car up until the wheels are off of the ground and then see if the tire wiggles around if it does the berring is shot if the tire is solid then the berring should be fine
Jun 04, 2012 | Chevrolet Blazer Cars & Trucks
I hear a grinding noise when i slow down
Could be the first sign of Brake Pad Wear , Check the outer edge of Disk for wear or deep groves
May 11, 2012 | 2006 Chevrolet Tahoe
Fan makes grinding noise when on speeds two and three. . . sounds fine on slow
The bearings are wearing out, speeds two and three are exerting enough force that the bearings are grinding, slow speed does not have enough force to do this. Soon enough, slow speed will make that noise and the fan will ultimately stop working. Have an electrician come in to look at it, if it is still under warranty, call Hunter.
Sep 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Clicking noise and red light instead of green...need data!!
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Apr 07, 2009 | Acomdata HD120U2FE-72 120 GB Hard Drive
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Thumping noise
2 things I would inspect, your motor mounts, and CV joints. If worn, one or both could cause what your experiencing. See if you can figure out where grinding is coming from, right or left side & check drive shaft CV joint on that side especially. Look close at both boots on them for rips or holes, where dirt has been entering.
P.S. a sloppy/worn CV joint can end up causing irregular wear on transmission as well, so don't let it go too long, if at all.
Feb 19, 2009 | 1993 Plymouth Voyager
Saniflo & Saniplus& Macerator Pump  Logo
619 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
