Question about JVC TH-M65 System
Th-m65 system discs will not eject. Cannot open any one of the two compartments. Disc 2 and 3 have are permanently lit up as red
snakehead
  • 1074 Answers
SOURCE: disc compartment won't open
Plug the dvd out then your plug it in back to reset it self.if that do not work take it to a tech to look at it the dvd ould be having a mechanical problem.the gears could be worn out or broken.good luck.
Posted on Apr 01, 2007
SOURCE: Disc tray
Something is causing the disc to get stuck inside the DVD player. Open it and inspect. If something is broken, take it to a repair center.
Posted on Aug 23, 2007
SOURCE: disc tray and playback problems
unlock codes for xv-thc5
Posted on Feb 14, 2008
SOURCE: JVC TH-M505 changer displays NO DISC
There are two rails in the dvd player. I have found that cleaning the rails & applying new grease to them usually solves the problem. a spray with silcone will do. do not get any on the laser. best done by a pro & not many know of this little trick.
Miyagi2
Posted on Jun 19, 2008
  • 22 Answers
SOURCE: blu-ray dvd disc error on jvc th-g41.
if your blu-ray is updateable then get update also try other disks
Posted on Apr 25, 2010
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
The disc is stocked in the disc compartment. We've been trying to eject the disc but it is not responding. What can we do?
Failure of the DISC loading mechanism and also the disc tray settings. This require correct timing to the mode switch and so if there is a shift the loading mechansim will be stuck up. So you will need some assistance to remove and reset the alignment.
Dec 23, 2011 | Audio Players & Recorders
Disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system
disc cant read the disc and will not eject the disc. I tried unplugging it and putting on and pushing eject. no good. what do you think bose 321 system ...
Oct 08, 2010 | Bose 3 2 1 GSX System
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
My dvd player is locked
If you are unable to get the tray of the dvd player open either the player will have a hole in front for you to stick a (I use a straightened out paper clip) into and press in towards the dvd player. It will manually open the drive so you can retrieve your dvd or there will be enough of a lip on the tray door you can grab it and pull it open manually. Then I would try unplugging the player and waiting a few minutes and plugging it back in and you might get lucky and it may never happen again. Good luck . Hope it works.
Jun 17, 2009 | JVC TH-M303 System
Can't eject dvd's.It says"LOCKED'How do you unlock to eject dvds
To unlock the JVC TH-C5 disc tray is by having the system off and at the same time hold the stop button and eject button until it says, "Unlocked".
Jan 10, 2009 | JVC THC5 Home Theater System with 5-Disc...
I have a jvc th-p7 cinema system. and when i try to open the tray it say's locked. but i dont know how to take it off?????
You can lock the tray and prohibit the unwanted disc ejection.
On the center unit ONLY:
While the system is turned off
• The system turns on and "LOCKED" appears on the display
window.
• If you try to eject the disc, "LOCKED" appears to indicate that
the tray is locked.
To cancel
Carry out the same operation again.
• The system turns on and "UNLOCKED" appears on the display
window.
Nov 27, 2008 | JVC Televison & Video
Disc won't eject
press the disc eject button
Jun 25, 2008 | Sony PlayStation 2 Slimline Console
Disc tray
Aug 22, 2007 | JVC TH-A25 System
Disc compartment won't open
Apr 01, 2007 | JVC TH-M603 System
JVC TH-M65 System Logo
32 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
