Question about Home
My geberit 260 dual flush wont shut off keeps leaking into bowl causing it to keep flushing
  • 454 Answers
The flush valve is leaking. Replace the gasket and your problem will go away.
Posted on Aug 05, 2010
My geberit model number 131.028 dual flush won't shut off with water and leaks into the toilet bowl
How old? Who installed? Any warranty? I'd follow that route first.
If not warranty I'd try to get the installer to be interested. Perhaps he will have a "red face" an help out.
Feb 27, 2015 | Geberit 131.028.SJ.1 Black Glass Monolith...
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
Leaky Seal
By leaking do you mean onto the bathroom floor, or is water escaping out the flush valve (the part that the Hydroright is seated in) into the toilet bowl. If the former 1) check toilet tank mounting bolts/gaskets for deterioration or looseness. These are usually 5/16"x3" brass bolts with rubber, plastic, and metal washers with a nut. They can be seen protruding through bottom of tank. 2) check flush valve and rubber gasket between tank and bowl. The flush valve is the one that the refill tube goes into and the hydroright seats into.
If you are only leaking water into bowl I would suggest the blue dome gasket ( part of Hydroright kit) is not properly seated properly into flushvalve, and you may have to re-install hydroright (the instructions explain how to remove and re-install) . I broke my existing/old flush valve at the base when trying to install my Hydroright so maybe it was fortuitous that it broke and I had to install a new one. Hope this helps.
Dec 15, 2013 | HydroClean Hydroright Dual Flush Converter...
Geberit model 150-403 toilet Water keeps running after flushing
I have the same problem with my new Gerberit 800 plus fitted last Thursday, it will not stop flushing in the manual it says valve problem contact service dept. Joke they dont give a number for them.
Feb 02, 2013 | Home
Water keeps leaking from the tank to the bowl
check and clean flapper if still letting water by replace
Jun 10, 2010 | Toto Aquia II Dual Flush Toilet
Geberit Impulse 260 Dual Flush Valve problem
need to adjust the float [water level shut off] lower or the water valve needs repair sometimes the valves stick and tapping the unit free's it up
Mar 01, 2010 | Home
My toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Oct 17, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Home Logo
1,134 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
