Question about Panasonic PT-53WX54 53" Rear Projection HDTV
PT-53WX54 53 in. Rear Projection HDTV Television
Hello Shuttle83,
First off, thanks for your help.  If this is a simple fix hopefully I can avoid paying $100 just to have someone diagnose the problem.  I tried to attach a picture to this, but it is saying the image is too big.  Do you have an email address I could send it to?  Again, I really appreciate your help.
JWade
    Genius:
  • 1,139 Answers
Hello jwade,
electronagetec@aim.com
Posted on Apr 26, 2008
My panasonic rear projection tv does not turn on the red light blinks 3 times
3 times red light blinking indicates that tv got problem of convergence output ICs failure and need to replace two big black ICs (convergence output) to solve this problem.
IC replacement requires soldering work and good knowledge of electronics stuff repair, please cal local tv repairman if you do not have prior experience of such work to avoid any damage.
Hope this will help.
Thanks.
Feb 28, 2011 | Panasonic PT-53TW53 53" Rear Projection...
PT-47WX53 47 in. Rear Projection HDTV Television
replace the DG board which is the small board which plugs into the A Board ( on the left side looking in rear of the set) The DG is the board which lays flat on top of the A board. You can get the A board and the DG board combined at www.tvrepairworld.com They may sell it seperately if you inquire.
Dec 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
A white screen that says set top diagnostics is on the screen
Hello pwon28,
This means that your set top box has been put into diagnostic mode and is showing on the TV. Power down your cable/satellite Set Top Box and then power it back on. This should clear up this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jul 13, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I have a Hitachi 53UDX10B 53 in. Rear Projection HDTV.
Hello iehoryna,
The answer is yes, you will be able to pick up and display HD channels. You will have to use your component video cables between your cable box and your TV. Component video will allow you to view low to medium end HD pictures.
I hope this helps,
Thank you,
Shuttle83
Nov 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Cleaning mirror
Hello mrdish,
the mirror is in the attached to the top rear panel, remove the top rear panel to clean the mirror.
I hope this helps,
Thank you,
Shuttle83
May 22, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Hello jwade,
This looks like it could be a problem in the Convergence/Deflection section. If possible could you send me pictures of the actual problem. Because they will let me know if this is a convergence or a deflection issue. The problem is these two sections are dependent on each other, but follow certain troubleshooting methodologies. Again post or send me pictures of the actual screen, and from that I should be able to help you.
Thank you,
Shuttle83
Apr 26, 2008 | Panasonic PT-53WX54 53" Rear Projection...
A question about the IC chips
Try vance baldwin, they have good prices and will sell to non service shops. Hope this helps
Apr 01, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Three pictures
Hello tdeg64,
This is not a picture tube problem. The problem has to do with convergence. I suspect that your convergence amplifiers are malfunctioning. As to this being repairable? Yes it is. However I would suggest that you get a qualified TV technician to troubleshoot and repair this problem.
I hope this helps,
Thank you,
Shuttle83
Jan 26, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Tv has green outline
Hello fameus2,
Try to adjust your convergence from you menu items. If this does not work, the problem may be your convergence Correction ICs but make sure you try to adjust your convergence first. There is a lot of information on the net about how to change the two convergence ICs (so I will not reinvent the wheel here). I would however suggest that you get a qualified TV repair person to do this for you since some folks have run into other issues in trying to do it themselves.
I hope this helps,
Thank you,
Shuttle83
Oct 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Philips 50PP9202 50 in. Rear Projection HDTV-Ready Television?
Hello Anthony14,
This is an indication the the red convergence amplifier has goone bad you will need to replace the convergence correction modules. Now before replacing these you may want to make sure that the bias resistors and the zener diodes are ok. The convergence ICs are part number STK329-110 or STK329-150.
I would suggest that you get a schematic and equipment to make the needed tests, or take the set to a shop to replace the bad components.
I hope this helps,
Thank you,
Shuttle83
Oct 14, 2007 | Philips 60PP9202 60" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
