Question about Car Audio & Video
Can you tell me how a kenwood kdc-7024 car stereo clips in to the unit cage is there supposed to be clips on the stereo its self or may i just have the wrong caga unit
Ok, for the kenwood models there is a metal clip on both sides of the cage, each side has one or sometimes 2 teeth that fit into the sides of the deck, picture enclosed, it should be able to slide in and "click" into place. hope that helps.
Posted on Apr 26, 2008
Kenwood kdc 7024 security code
Hi Chris,
Beginning on the bottom of page 34 in the KDC-7024 manual - you'll find the details concerning the security code. if you do not recall your security code, you will probably need to contact Kenwood Car Entertainment Support for additional help.
I hope this is the info you're looking for & good luck!
Sep 22, 2011 | Kenwood KDC-7024 CD Player
Code kenwood kdc-7024
You will need to visit an Authorized Dealer or service center for that product to get the unlock code reset. You can find a dealer listing on their website, or call them.
Dec 03, 2010 | Kenwood KDC-7024 CD Player
Need to remove kenwood kdc 315s stereo to replace my heater unit on 95 civic, how do you remove stereo?
If you remove the outer trim ring look on each side toward center edge you will notice 2 slots one on each side of unit. You will need a set of Kenwood keys to remove the unit from the cage. If you do not have the keys for the unit you will need to take it to a stereo install/repair shop and have them to pull the unit for you.
Hope this helps!
Sep 26, 2010 | Kenwood KDC-315S
I dont remember my 4 numbers to my kenwood KDC-7024 cd player i just got it from my uncle and he dont remember what it was
The only solution now is to take it to a Radio Decoding Service (such as your local Car Radio store) where they will open up your radio and connect a laptop to read the code inside your memory chip(EEPROM) using special software.
It will not be available by any other method as KENWOOD codes are not readily available ...Sorry
Sep 01, 2010 | Kenwood KDC-7024 CD Player
Cable
The difficult part is I have a KDC-X815 and you have a KDC-7024, so I have no idea how different they are internally/mechanically. But if it's any help, here are the (excellent) instructions I used to repair mine. I was able to find a replacement cable at a local stereo shop that also does stereo repair.
http://www.csupomona.edu/~bvnorum/faceplate_ribbon_cable_replace_kdc-715s.pdf
This forum thread has a lot of good info, too:
http://forum.ecoustics.com/bbs/messages/4/162949.html
Jul 23, 2008 | Kenwood KDC-7024 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
My Kenwood KDC-7024 has just started playing up - as soon as you turn on the ignition, the face panel comes down, flicks on for all of 2 - 3 seconds and then closes, it then keeps doing this repeatedly...
It's possible the flexible PCB (more of a cable, really) that connects the faceplate to the main unit has cracks in the conductors. This has been an issue with some of the older Kenwood HUs that have the MASK motorized faceplate. The flex-cable gets bent and pinched enough over the years that it eventually cracks the copper.
Mar 07, 2008 | Kenwood KDC-7024 CD Player
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
Car Audio & Video Logo
100 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
