Question about Canon imageCLASS MF4690 Multifunction Laser Printer, Copier, Scanner & Fax, 21ppm, Maximum Size: 8.5
MF 4690 PL. Machine cannot print or scan. Message on LCD display is "Check document". Indicator light blinks red.
SOURCE: Canon Laserbase MF5650
Only thing I do is to re-boot the printer and check your print size is the same as the paper size in the printer.. pretty poor this
Posted on Feb 07, 2007
SOURCE: Will not print
Okay ya'll I've dealt with this problem twice. The first time it was super frustrating but eventually I figured it out.
First things first turn off your printer, unplug the USB connecting it to your computer.
Restart your computer (with printer not USB not connected to it)
Now comes the fun part. Open the middle area of your enormous printer and take out that stupid printer cartridge. Now put it back in.
Each time this error has happened to me these actions have solved the problem.
Oh yeah and for all of the new owners of this printer, this error can easily happen to those who forget to take out that strip that is on the side of the brand new printer cartridge.
Posted on Oct 17, 2007
  • 117 Answers
SOURCE: HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
Posted on May 06, 2009
goodgold
  • 389 Answers
SOURCE: i have a canon mf 4690. I don't know how to do
To operate the test mode, after pressing the Menu key, press the # key and select "SERVICE MODE". After this, select "TEST MODE" with the cursor keys, and press the OK key.
FACULTY Tests
The faculty tests are selected by pressing the numeric key 6 from the test mode menu.
Posted on Nov 04, 2009
angelo_mlc
  • 1035 Answers
SOURCE: Cannon MP830 will not scan
Hi. Error code: 2,178,0 means the scanner lamp is out, you need to replace the CCFL lamp.
Posted on Nov 06, 2010
Tip
Canon image CLASS MF5700 Series Scanning
Scanning with [Start] on the Machine
By pressing [SCAN] [Start] on the operation panel of the machine, you can scan
documents to your computer.
Pressing [SCAN] [Start] has the same effect as clicking [Save] in the MF Toolbox.
You can change the settings for [Save], or set up a button other than [Save] to
perform the same operation. (See “Setting the Scanning Function for [Start],” on p.
3-3.)
NOTE
You can use the machine for only a local scanner (connected directly to your computer).
1 Place the document face-down on the platen glass or load it
face-up in the ADF
2 Press [SCAN] [Start] on the machine.
If you are asked to select a program to launch, select “MF Toolbox Ver4.7.”
Scanning starts.
The MF Toolbox and the [Save] dialog box will open, but the document will be
scanned without pressing [Start] in the [Save] dialog box.
The scanned document will be processed according to your settings.
When you use [Start] for the first time, a folder with the scanning date will be created in
the [My Pictures] folder in the [My Documents] folder, and your document will be
saved in this folder. If there is no [My Pictures] folder, the folder with the scanning date
will be created in the [My Documents] folder and your document will be saved in this
folder2 Press [SCAN] [Start] on the machine.
Scanning starts.
Scanning starts.
folder
on Dec 08, 2009 | Office Equipment & Supplies
Not installed toner check Y error message
replace the yellow toner container with OEM NOT THIRD PARTY
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 27, 2016 | Konica Minolta Magicolor 4690 MF Laser...
How do I get the scanner to scan several pages into one document instead of each page being an individual document
Dear
Pl. do select the multiple page in scanner software (application) setting, and format setting to pdf type.
Thanks.
Feb 26, 2015 | Canon MF-4150 imageClass Black & White...
How do I override a paper jam error message?
Dear
I am a bit of confused about paper jam but you are able to print but facing difficulties in scanning. I think the document jam is there. Pl. check the ADF (automatic document feeder) a small piece of paper or any foreign mater may obstruct or jammed at the sensor. clearing this may help you.
Thanks.
Feb 25, 2015 | Brother DCP 8085DN
4690 MF Printer displays the following message:"SCANNER MOTION ERROR, CHECK SCANNER LOCK"
I would open up the scanner and check to see if it can move, When you turn on the machine does the scanner try to move before the code shows up.
Feb 18, 2015 | Konica Minolta Office Equipment & Supplies
System error e225
Hello 3G,
To resolve the issue Error e225,
Turn the main power switch off and then back on-ICMF 4000 series/D400 Series
or
Update the firmware :
There is a risk that the MF4150 will not operate if power interruption occurs
during the firmware update. Please make sure MF4150 is connected to
reliable AC power source.
1. Save the downloaded file "MF4150_FirmwareUpdateTool_V0xx.exe on local drive. (i.e. desktop)
Computer Requirements for update
- Microsoft Windows 2000 or XP (32bit)
- Equipped with a USB port (either 1.1 or 2.0)
- Free disk space: 100 MB or more
2. Make sure that Processing/Data indicator (Green LED) on the MF4150's operation panel is turned off.
If the light is lit or blinking, wait until all the jobs are finished (i.e., COPY, PRINT, and SCAN), and that the Processing/Data indicator is turned off.
3. Make sure that Error indicator (Red LED) on the operation panel is turned off. If Processing/Data indicator (Green LED) is lit and Error indicator (Red LED) is blinking at the same time, jobs are held in the printer memory due to an error, possible cause is out of toner or paper has run out, or toner cartridge is not installed. Check the LCD for and error message and refer to the documentation that came with the printer to resolve the error.
4. Disconnect Fax line cable from the MF4150 to prevent Fax reception interruption during firmware update.
5. Make sure the USB cable is directly connected to the MF4150 and your computer.
  • Do NOT use a USB hub to connect the cable, as it may lead to a connection error.
  • Make sure the machine is not in the Sleep mode (i.e., [Energy Saver] key on the operation panel is leit). To exit the Sleep mode, press [Energy Saver] and confirm that the Energy Saver light is off.
  • You need to log on as an administrator to perform this update.
  • Make sure that no other applications are running on your computer.
6. If [Found New Hardware Wizard] appears on your PC screen, click [Cancel] to exit the screen.
  • [Found New Hardware Wizard] screen may be displayed multiple times. Cancel anytime you encounter this screen while performing this update.
7. Double-click ?MF4150_FirmwareUpdateTool_V0xx.exe? that you downloaded and saved.
8. Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
9. Confirm that the machine is in the ready status, and then click [Transfer]
  • If the printer is not detected: Check if the printer's power is turned on and the USB cable is properly connected. Then click [Retry] to proceed.
10. The firmware is transferred to the printer.
  • Never turn of the power to the MF4150 while firmware is updating. If power interruption occurs while the firmware is being updated the control board will be damaged and will need to be replaced. The replacement of the control board and labor will not be covered under warranty.
  • If an error occurs while transferring the firmware: Check if USB cable is properly connected. Click [Retry] to proceed.
11. When [Firmware transfer is complete] appears, click [Exit].
The printer starts the update process automatically.
<ERASE FLASH ROM> appears on the printer's display while the existing firmware is being erased.
Then printer's display shows <FIRMWARE UPDATE> while updating the firmware.
When the firmware update is complete, the printer's display shows <FIRMWARE UPDATE OK> <MACHINE POWER OFF/ON>
12. Turn printer's power switch OFF, wait 2 seconds then turn the power switch back ON. Check that there is no error on the printer display. Reconnect removed fax line cable.
Jun 22, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Canon imge class mf 4150 e225 eroor?
First:
Try to get the latest firmware at LINK.
Here is how to:
8. . Double-click "MF4150_V0xx_FirmwareUST.exe" that is in the newly created folder as a result of uncompressed downloaded file.
Feb 23, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
The error light came on and I don't know whats wrong
What is the error light
Step one: Identify the specific printing problemIf your All-in-One won't print, first you need to identify the specific issue or symptom. What exactly happens when you try to print? Do you see an error message or do the lights on the printer start blinking (flashing)? Does nothing happen at all? Follow these steps to identify your unique printing issue before troubleshooting. If you can identify a symptom based one of these methods, make a note of the symptom, and then continue to the next step. Method one: Look for blinking lightsLook for any blinking lights on the front or top of the All-in-One. Sometimes just the power button can blink, or a small indicator light on the printer can blink, or a combination of buttons can blink all at once. Example indicator lights on the printer Attention lights Wireless indicator light Cartridge lights Error Lights c01890693.gif c01890694.gif c01890695.gif c01890697.gif c01890698.gif c01890699.gif c01890700.gif c01890701.gif Example blinking lights patterns
c01890702.gif Method two: Look for error messagesPrinting problems are usually accompanied by an error message of some sort, usually on the control panel display (if your All-in-One has one), or on your computer monitor. Check both places for specific error messages. Error messages might or might not be accompanied by an icon representing the error. Following are some examples of error messages you might see on your computer screen or control panel display.
  • c01890703.gif 'Printer is Offline '
  • c01890704.gif 'Align Cartridges '
  • c01890705.gif 'E ' (error condition)
  • c01890706.gif 'Document(s) pending ' (Roll your mouse over the product icon in the lower-right corner of the computer screen.)
Jan 16, 2010 | HP DeskJet F380 All-In-One Printer
Red ! mark. LCD panel says: Error...Printer
The waste ink tank is full.Read this instruction.
If this not help there is a manual reset for this printers but I'm not tried yet.
  • Press and hold B/W+COLOR+STOP button.
  • Press power button, don’t release all button until you see the led indicator blinking and a message display on the LCD.
  • Release the button.
  • Press COLOR button to clear protection counter
  • Turn off the printer by pressing power button.
  • DONE!
Oct 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Canon imageCLASS MF4690 Multifunction Laser Printer, Copier, Scanner & Fax, 21ppm, Maximum Size: 8.5 Logo
180 people viewed this question
old marine
old marine
