Question about Logitech Z-10 Computer Speakers
Logitech Z-10 sound like it has 2 blown speakers(bass rattle), anyone tried to fix by opening and changing speaker?
5 Suggested Answers
SOURCE: HOW TO DISMANTLE THE SPEAKERS Z-10
okay...this is not pretty, but it's the way I did it, and Logitech have not made these easy to dismantle. The shiny front panel is actually glued onto the speaker chassis, and must be carefully and slowly pulled off the aluminum chassis, Take great care not to scratch or excessively bend the faceplate as you ease it away - the glue is elastic, but has a very strong grip, so this requires a fair bit of force. Start at the top corner and gradually release the entire fascia. When you get down near the display, take even greater care, because there are all kind of delicate controls under there. Don't poke anything into this area, but continue pulling a bit at a time until the entire front comes off. I used a strong but thin screwdriver blade to get a start on the edge - the silver trim stays where it is on the chassis...don't try to remove that, as it has nothing to do with disassembly! Once the faceplate is off you have access to the small philips screws - 8 or 10 (by memory) that actually hold the front of the speaker chassis to the rear casing. I used a long, strong screwdriver to remove these - they are in pretty tight. That gave me access to the whole speaker internals, including the circuit board. I kept the front fascia safe glue side up, and was able to carefully replace it using the original glue. I checked everything was still working...and it is. Next I will take it apart again to change the capacitors (that's the fault with mine, which makes an intermittent static crackle sound that is unaffected by the volume control). Once again, move slowly but firmly to avoid damaging the fascia, and good luck!
Posted on Jul 19, 2010
Fusiondc
  • 47 Answers
SOURCE: computer speakers logitech z-10 2.0 lcd
Ok check out this website for the software package installation for your speakers. Look to the right after you click the link and choose your operating system.
http://www.logitech.com/index.cfm/439/202&cl=us,en
After you are done installing the software for your computer speakers. A little icon will appear in your system tray at the bottom right of the computer screen. Click that icon and you can change your speaker settings there.
I hope this helps! if you need more help please ask!
Posted on Jan 25, 2008
  • 118 Answers
SOURCE: I have logitech speakers for my computer. I need a
logitech rarely has replacement parts. and for this model is not for the u.s. distribution so youcan not even call u.s tech support for help. try ebay or craiglist. if the connector is not proprietary you might be able to get a electronic repair shop to repin the connector.
Posted on Jul 24, 2009
  • 2386 Answers
SOURCE: No CD and cannot find driver for Logitech R-10 speakers-HELP
The R10 speakers are analog speaker drivers are not needed, you may need drivers for your sound card-- quick test plug a headset into the green port on the back of your computer. if there is sound coming thru then the sound card is fine and you need to make sure your connection are correct. if no sound, plug the headset into the front ports for headphones. if sound is coming thru there but not in back the sound card needs replacement the port is bad.
Download the drivers from this link
http://www.logitech.com/index.cfm/downlo...
if you still have a problem try
http://logitech-en-amr.custhelp.com/cgi-...
Hope this helps :)
Posted on Sep 15, 2009
Fishman Loudbox amplifier rattle sound on bass notes
Either the speakers have loosened from the faceplate, or one or more have blown. Open the amp and tighten them down. If that doesn't fix it, remove them a take them to the nearest speaker repair shop for a checkup. If blown either have them re-coned or replace them.
Oct 06, 2016 | Fishman Loudbox 100 Acoustic Guitar...
Woofer rattles at low volume...when i turn it up it sounds pretty good...still has bass and highs
May be a couple of things; The first is a resonance in the cabinet, which may not be noticeable at high volumes. If the speaker cabinet was ever dropped,or got cracked from dropping , dry weather,or whatever, there may be certain frequencies that make the cabinet rattle. Try holding the cabinet when it rattles and look for anything loose,from a side wall to a loose foot, or the speaker itself. Tighten up loose items and seal any gaps or cracks On the cabinet.
The other problem could be a partially blown speaker. Test by lightly pushing in on the outsides of the speaker to see if it moves in and out freely. If there is a scratching sound, or it drags slightly , it might be blown. Also,the dust cap or another part of the speaker may be loose. Check that, and reseal if loose. Replace or have reconed if blown.
Nov 02, 2014 | Mackie MR8 ACTIVE STUDIO MONITOR MR-8
Buzzing noise z4 logitech speakers
Hi Haley,
I also enjoy good Music and excellent sound from my speakers that i have and know what you going through. There is two problems that i see here. One is that your bass speakers is dying on you from the excess bass that has been exerted throught it or have you tried lowering the adjusting bass from the contol panel?
Try adjusting the bass and if that doesnt work aleast you've identified your problem.
Thanks Haley for using Fixya.Good Luck.
G..
Nov 03, 2011 | Logitech Z-4 Computer Speakers
A gift was just given to me. They are the Logitech Z623 speakers. But, they came with no documentation. When I plug them in as intended with either my HDTV or my desktop pc, only one of the satellite...
I checked Logitech's website and they don;t have any downloadable documentation for this product. Anyway, let's just try and fix it.
First, make sure your left and right speakers are connected properly to the bass speaker.
Next, the wire from the bass should be connected to your soundcard's line out port (light green) or into your TV's audio lineout.
You can also adjust the volume of your bass separately on the right speaker.
Update me if this worked or if you are still having trouble.
Thanks for using Fixya!
Jun 12, 2011 | Computers & Internet
My speakers sound is no longer perfect
Blown fuses are SOLID dead circuits, not bad sound.
Try different speakers first. If the electronics was cooked it would probably be silent.
May 18, 2010 | Polk Audio RTi100 Main / Stereo Speaker
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
Bass rattling on Bose Companion 2
My Companion 2 speakers were having the same problem with the rattling on certain frequencies and I am happy to say that Steve Allison was correct in my case. The speakers don't handle surround settings very well so if you're running your speakers through a source that had that setting turned on the easiest way to stop the rattling is to just turn the surround setting off. The speakers weren't really made to handle that kind of a signal.
Jul 14, 2009 | Bose Companion 2 Series II Multimedia...
Subwoofer rattle
Try filling the inside of the enclosure with insulation [roof insulation will work ] or a small pillow just to see if its the box or the driver rattling if its the driver you might have to secure it to the enclosure with screws or something ,
May 18, 2009 | Atlantic Technology System 170 System
I have a 10" kicker that made a rattle noise for a while when the bass hit but quit working completly now what caused the rattling noise and could it be fixed?
the speaker may be blown , but the output should be checked for sound , if no sound output then it would mean the amp quit
Oct 06, 2008 | Audio Players & Recorders
Bass destortion
yes u nee dto get the kilspe 2.1 promeadia speakers way better big bass rocks seprate bass control used set on ebay for 65
Feb 02, 2007 | Logitech R-20 Computer Speakers
Logitech Z-10 Computer Speakers Logo
610 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
