I have bought a Ferguson, F20250DTR, Digital TV Recorder, and it seems to have installed ok, the scren shows which channel and what is on, but there is no picture or sound. Can you help?
Have you checked that the SCART plugs are firmly in at both ends?
Posted on Aug 27, 2010
I have just bought a new smart TV how do I connect my recorder to it it is a Ferguson brand recorder
Try looking at the Ferguson website and the TV mfr's site for this information.
Nov 20, 2017 | Televison & Video
F10500PVR ferguson digital recorder
After 5 years, and you have tried to set it up again, its probably had it.
Turn off all power to it for 10 mniutes then carefully do the setup again. If its still bad its time to replace it.
Dec 15, 2013 | Televison & Video
I bought a FERGUSON F20320DTR Digital TV Recorder At first I really liked the product but when I changed my TV from a really old one to a new LG 37LD450 I started to lose channels. At first I was unable...
If you are in an area that is being switched over from analogue to digitial you might lose channels to do with that. Another reason could be the leads between the TV and Aerial connections. Make certain that they have good connections and use proper screened cables. Some people also have several transmitters around them, some of which have weaker signals than others. Some channels will therefore not appear. Check the box is tuning into the strongest signals.
If you manual retune then find out the frequencies of the strongest transmitter in your area first and set it on them.
Aug 23, 2011 | Televison & Video
Bought a new 32inch tv with added freeview. I have a ferguson dvd/vcr combi which has tuned channels 1 -5 ok but how do I tune the digital channels
You're going to need to use your menu button and do a channel scan.
When it completes use the save option if present and exit the menu.
Mar 11, 2010 | LG Televison & Video
Unable to install correctly - hd tv ok - dvd wont install
what type of cables are you using? are you using the HDMI cable that comes with the unit? your tv also has to be HD compatitable.
Dec 19, 2008 | Philips DVDR520H DVD Player/HDD
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Sep 27, 2007 | Televison & Video
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
Televison & Video Logo
320 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
