Question about Nikon Science & Laboratory
Microscope won't come on! Found blown fuse on power supply board. Need part# and price for power supply. The model # of microscope is 50i ,serial#813002. Part#on the power supply is HSV3-30N is this a good #? Thanks
  • 72 Answers
SOURCE: vista driver for Intel QX3 Microscope
Instruction for installing the QX3 or QX3+ Microscope with Vista
Note, DO NOT use the software from the CD that came with the microscope.
DO NOT plug in the QX3 microscope until Step 4.
Step 1. Install the QX3PLUS.EXE software downloaded from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&Inst=Yes&ProductID=160&DwnldID=4419&strOSs=All&OSFullName=All%20Operating%20Systems&lang=eng
Step 2. Download and install the QCODINSTL.EXE software from:
http://www.intel.com/support/intelplay/qx3/sb/cs-016002.htm
Step 3. Download and extract the QX3 Drivers from:
http://hyperslug.s3.amazonaws.com/IntelQX3driverXP.zip
Step 4. Now, plug in the microscope.
When the "Found New Hardware" wizard appears, select "Locate and install driver software (Recommended)", a message "Installing device driver software" will appear. If you click on "details", you will see "Searching Windows Update", after a while you will be able to select "I don't have a disc. Show me other options" and browse to the folder with the extracted QX3 drivers from Step 3. above. The hardware should install successfully.
Double-click on the QX3+ icon on the desktop and the program should run.
Posted on May 24, 2009
SOURCE: Intel Play QX3+ Microscope
Try a different computer and install the QX3Plus application (for Win 2K-XP). If it works okay, then completely remove (uninstall) it from your Dell 4600 and clean up the registry of unusable strings (try Advanced Registry Optimizer, its a free download). Then do a clean QX3Plus install BEFORE you plug in the USB cable. If the QX3 did not work on a different computer, the QX3 is faulty and maybe you should look at the QX5 as a replacement. The QX3 was discontinued at around the turn of the Century. However, if you are only missing the SPLAT; try locating the green button at the lower left corner of the image screen, it produces drop-down dialog boxes to splat screens. Good Luck!
Posted on Jan 07, 2008
  • 45 Answers
SOURCE: I Can not find a manual for my Tasco NO P750 microscope,from 1984
Call tasco 1-800-423-3537 and ask for one.
Posted on Jan 30, 2009
SOURCE: QX5 Problem with Windows Vista
Do not plug the QX5 in until the software is installed.
I got mine to work on Vista 32bit. Insert the cd, cancel autorun, view files on the cd. locate setup.exe, right-click on the setup and go to properties; then compatibility; then put a check in "run this program in compatibility mode for windows xp" AND put a check mark in "run this program as an administrator; the click Apply and click OK.
Right-click on the setup.exe again, this time choose, Run as Administrator.
Install away from the default. My recommendation is c:\users\(your user name\digitalblue.
Plug in the QX5, then go to Start, Programs, Digital Blue, click on QX5
Posted on Mar 05, 2009
SOURCE: Premiere usb microscope eyepiece software drivers
http://www.cnascientific.com/Contact.aspx
Demand a Windows 7 Driver here
Posted on Oct 11, 2011
Remove collector and open base of Nikon Labophot
send an image of your microscope so that I maybe could help you,my email address is:r.chitchian@yahoo.com
Feb 18, 2010 | Nikon Science & Laboratory
I need ti find a spare electric board for a PREMIERE MRJ-03.
Check the cable connections, a cable might be loose or just disconnected.
May 08, 2009 | Premiere Microscopes MRJ-03 Microscope
Nikon Optiphot-2
You should start by changing the bulb, even though it looks ok chances are that it's no longer working. Do the same with the fuse if the new bulb doesn't work.
Test that power is reaching the socket with a voltmeter or a multimeter so ensure the wiring is ok with the new fuse. If no power is reaching the bulb socket, then you will need to check the wiring every step of the way.
Apr 18, 2008 | Science & Laboratory
Qx5 microscope is shutting down.
Does this device run from USB power.. (no plug in power supply) if so, the problem may just be that this device (not limited to microscopes) is trying to draw too much power, as not all USB ports are born equal (a common problem in laptops). the solution is to either buy a power supply for the microscope or get a "powered" USB hub (a usb hub with it's own plug top power supply) I hope this helps
May 25, 2007 | Digital Blue QX5 Microscope
Qx5 is not responding
the microscope may be trying to draw too much current from your USB ports, your computer will disable the device if it does this. When this happens one of the easiest (and cheapest) solutions is to acquire a Powered USB Hub (with it's own Plug top power supply). This should aleviate any extraneous current draw to the Power supply.
Apr 28, 2007 | Digital Blue QX5 Microscope
Science & Laboratory Logo
243 people viewed this question
Top Nikon Science & Laboratory Experts
Marvin
Marvin
matt
matt
Don A
Don A
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
