Question about Xerox Phaser 6100/DN Laser Printer
We keep getting the "ADC not Confirm" error message when printing and nothing prints on our Phaser 6100/DN. We have to turn the printer off than back on to clear the message.
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 208 Answers
SOURCE: Xerox Phaser 6100- Error message - "Fuser Error Low Temprature"
Try this before replacing the fuser.
You do have to reset a new fuser also.
Reset Fuser Life
  3. Scroll to Fuser, press Reset.
  • 2072 Answers
SOURCE: Xerox Phaser DN error code 09,036,44:2976
Hi, Yep, that's normally an easy one. That code means one of your ink sticks, I think the .44 means magenta, but, one of the ink sticks has not advanced downward properly into the ink loader.
One of the ink sticks has twisted, cracked or otherwise for some reason is not advancing downward into the bottom of the ink loader to melt. Look in there and see where there is a gap. If you need to, take a screw, like a drywall screw and twist that into the ink stick if needed, then slide it back to remove.
If its just stuck then push it down to the proper position.
If you somehow loaded an ink stick for the wrong machine, the different shape will not allow it to actuate the switch at the bottom of the ink loader and will have to be removed.
Posted on Aug 13, 2008
  • 3 Answers
SOURCE: Problems with printer settings
Interesting. I tried printing a simple 3-page Excel spreadsheet sent my by a colleague to my 8500DN from Microsoft's Excel Viewer and got a timeout error formatted as follows:
ERROR: timeout
OFFENDING COMMAND: timeout
STACK:
42
-mark-
(84,160)
No idea what this means, but resetting the network parameters (even though I use USB connection) from the printer's front panel cleared the problem. The printer would print nothing else from any program until I performed this reset. Wonder if Excel futzes with settings and printing somehow?
Posted on Oct 15, 2008
  • 49 Answers
SOURCE: Phaser 7750 - printing slow
Have a look at the link below for the solution!
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Niallbt
Posted on Mar 30, 2009
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Phaser 5500 will not duplex
its definitely a driver related issue.....download latest driver from www.xerox.com
Nov 09, 2009 | Xerox Phaser 5500/DN Laser Printer
Xero phaser 8500 red light on can not print
Is there an error message or error code appearing?
Mar 19, 2009 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 error 13,327.42:31555
If you have Warranty Still, CALL XEROX!!!, That error message indicates that you have a failed temprature sensor inside the print-head, 90% chance Xerox will have to replace print-head. Print head is VERY expensive to replace out of pocket ($500-800+)
Jan 23, 2009 | Xerox Phaser 8500/DN Printer
ERROR: timeout
STACK:
42
-mark-
(84,160)
Oct 14, 2008 | Xerox Phaser 8500/DN Printer
Error Message 07,010.43:68691
That is the code when the Print head is not pivoting back and forth.
In order here are the most likely problems.
1. On the right hand frame there is a staineless steel pivot block, about one inch square that the print head shaft runs through. Some, and most likely Yellow ink has seeped into that pivot block not allowing the head to move freely.
2. One of the cables that are attached to the print head are caught on some item holding the print head back.
3. The mahine was unplugged or lost power with the wiper blade tacked to the print head, jamming it between the print head and drum.
That code is telling you that the print head is not pivoting beween the home and operating position.
Very common. Also very very unlikely the print head has been damaged or defective.
Jan 08, 2008 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500 reports Internal Error
I would suspect the elecrtonich module has gone bad.
Without an error tht is my best guess.
Oct 23, 2007 | Xerox Phaser 8500/DN Printer
Colour Printing
YES, Possible faulty / contaminated Transfer system, I would get this serviced, as this is a more complex fix
Aug 22, 2007 | Xerox Phaser 6100/DN Laser Printer
Printing problem
This error message indicates that the printer memory is full. You might be sending too many documents to print at the same time. I would suggest dividing the number of documents/pages into smaller groups so the printer can take the load. Hope this helps!
Feb 22, 2006 | Xerox 6100/DN Laser Printer
Xerox Phaser 6100/DN Laser Printer Logo
2,156 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
