Question about Acomdata HybridDrive E5 Hard Drive
My external acomdata hard drive is flashing from red(primarily) to blue and will not let me view data on it. how can i fix this issue
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    ACOMDATA HD160U2E-509 NOISE AND FLASHING RED AND BLUE
    My External HDD in your picture :D
    Turn your HDD off & back on
    Jun 11, 2011 | Acomdata 500GB External Firewire HD 500 GB...
    Acomdata 250 external (SATA) hard drive not showing up on desktop
    be safe
    go on line to acomdata web site and down load the driver from there
    Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
    My Acomdata (500gb?) external hard drive isn't working
    Place it onto another computer, if you can see it and access it then plug it into a differant USB port on your computer.
    Jan 14, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
    Problems with Hard Drive
    Appreciate the direct "Ask Me".
    T your concern:
    • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
    • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
    • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
    • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
    • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
    • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
    • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
    • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
    • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
    • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
    • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
    • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
    how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
    Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
    Red and Blue flashing light
    I have the same problem. I have a 500 GB hard drive and my computer will see the hard drive but it won't let me open it. It says "g:\is not accesible incorrect function" I have a lot of data in my hard drive and I don't have it backed up anywhere else so I really need to be able to be able to open the drive.
    Jun 20, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Freezing Upon Log-In attempt
    red usually means that reading has encountered an error or that it has encounter a corrupt file thats why it freezes. try to recover those files using recovery software.
    Dec 02, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Acomdata HybridDrive E5 Hard Drive Logo
    196 people viewed this question
    Top Acomdata Computers & Internet Experts
    Donna Sander
    Tom
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
