Question about Saeco Magic De Luxe Espresso Machine
My saeco water light is flashing.what does it mean?
  • 6,993 Answers
The flashing light means that it is time to change your water filter.
If you don't have a water filter or if you have just changed it, press and hold the steam button for about 5 seconds and then the red light should go way.
Good luck
Posted on Aug 05, 2010
I have a Saeco Incanto S Class rondo I think it is an older version as very manual no computer. It has a flashing red light on left side (where coffee comes out) it has a ~~ on it. The machine still...
That light indicate that you need to change the water filter in the tank. The water filter is either an Aqua prima
or intenza filters. If you are not using the filter I would suggest to just reset the light. You can reset the light by holding down the water button under the coffee brew button. Looks like a water drop.
You can also download the manual at www.CeriniCoffee.com
Apr 11, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
If I want to leave my Saeco Odea Go turned on for a few hours I am not able to make any coffee and I am getting a flashing green light unless I turn off the machine and start it again. What is the problem?...
hi,
when the machine is On for long time ,it going in the STAND BY MODE-green light is flashing slowly.Just press coffe button and wait for a 10 seconds.
When the red light is ON and no flashing it is mean there is no water in the water tank or too much water in the drip tray.
Dec 29, 2017 | Saeco Odea Go
Saeco Magic Delexe water light flashing
The brew unit is blocked, check the shower screen under the red o-ring.
Dec 03, 2009 | Saeco Magic De Luxe Espresso Machine
Spidem Divina - one cup and 2 cup lights flash together
Hi
Caution light usually means something is out of place. Nothing will work until everything is in place and locked.
Steady water light means it needs to be primed, (run water by opening the steam knob). It won't heat until the boilers are primed.
Jun 19, 2009 | Saeco Spidem Divina Deluxe Fully Automatic...
3 flashing lights stay on all the time?
I have the same problem. It seems that the group motor issues. I ve opened up and found the group motor is coming some sparks. I know very well Saeco Magic Cappucino , Saeco range is more or less the same, Saeco incanto, first time deal with it , somebody just brought it to me to check it. I might fix it if find parts for it.
Load circuit means a lot, flow meter, pomps, could be the electronc board, bewing unit blocked up with coffee, so basically there is no water in circuit water or is air in water circuit....You have to check everything,
Mar 01, 2009 | Saeco Incanto Coffee Maker
Saeco Odea cappucino machine warning light
I think you have to go to a Saeco service center to look on it, it can be a sensor that is faulty.
Dec 29, 2007 | Saeco Coffee Makers & Espresso Machines
Part 2 -Flashing water light - will drain water but will not make coffee
Blinking light often means pump is not delivering water. Possible blockage from corrosion. Can also mean a valve blocked.
Do you hear the pump run?
Dec 11, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
54 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
