Question about Brother HL3040CN Laser Printer
Brother hl3040cn. I have replaced black cartridge it now says other 3 need replacing. Was printing ok before black ran out; not printed colour for long time. thanks
This printer tells you to replace the toner when there is still plenty left. You can override this as follows:-
1. Open the top cover
2. Press "Secure print" and "Cancel" together
3. This brings up the cartridge menu. Press "OK" twice for each entry, then scroll down to the next one. There are two entries for each colour, dunno why.
4. When you've done all 8 entries shut the lid and print.
This may need to be redone every few months.
Posted on Nov 12, 2010
  • 1 more comment
  • Seymourloo Feb 09, 2011
    Thanks Petet1962 - you saved my sanity as I had a deadline and the printer wouldn't recognize I'd changed the 'low' cartridges!! Made my deadline, and you will likely save me a whole lot replacement cartridges in the future too! :D
    Pam
  • BBANNER May 15, 2013
    This has been killin me for months! Thanks so much!
  • Richard Stolz
    Richard Stolz Oct 25, 2013
    Stickdolz- I am frustrated with this printer. I tried the above instructions (press SPrint and Cancel buttons) but the machine tells me to close the cover which brings back the original "replace all color cartridges" message. These are all original cartridges but I can see toner inside and have taped of the visual beam window. Help
Hi There, I have a brother DCP-130c printer and one of the colour ink has run out. I need to be able to print with just black. Is there a way to print without replacing colour ink?
When you click on print, click on print preferences. As shown in image below.
On the preferences window click on Paper Quality tab and click on black and white. As shown below.
Click on OK and then click on print.
Note: Few new printers wont print till you replace the empty cartridges.
Regards,
Shrey
May 31, 2011 | Brother DCP 130C All-In-One InkJet Printer
Hl3040cn prints a black stripe down the page despite the drum being cleaned as advised by Brother.Peter
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 15, 2011 | Brother HL3040CN Laser Printer
Black won't print
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 490cw Color Inkjet...
Brother MFC-290C not printing black
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
Brother mfc3360 blank ink doesn't print
brother is good printer,there are many facitil as we can block one type colour as black or colour . look once a time in your printer option.or setting. , Is there on type colour is set only?
Jun 20, 2009 | Brother MFC-3360C All-In-One InkJet...
Black doesn't print
I have same problem. Found if I remove and replace the black cartridge before I send a print job it will work. Be interested to know if that works for anyone else.
Oct 17, 2008 | Brother MFC 210C All-In-One InkJet Printer
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Nothing prints
replace all colours and it will then print
Aug 28, 2008 | Brother Multi-Function Center MFC-665CW...
Brother HL3040CN Laser Printer Logo
1,565 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
