SOURCE: Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
SOURCE: Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
[email protected]
pallesappliancerepairs.com
SOURCE: Machine filled with water itself and does not empty.
Power off the mains. The
filter is located behind the silver plate at the back of the machine at
the
bottom. Four screws hold it on. Drain
out all the water. The filter is inside
the big black rubber hose attached between the pump and the main drum.
Remove
the plastic clip holding it to the pump unit and then the metal cir clip
holding it to the main drum. Inside is a white molded cone and a big
white ball
which floats. You will find a lot of junk here, clean out thoroughly. To
refit
put white cone back inside just as you found it, at the bottom, fit ball
back
into the cone. Attach to the bottom to the drum and re-fasten the cir
clip.
Finally reconnect the gator to the pump unit and tighten the plastic
clip. Check out the pump too before reconnecting.
And rate me nice pl for the
free help!
