Question about Ricoh Aficio 450 Copier
My copier is producing dirty copies what can i do
    Habit-Forming:
  • 96 Answers
Try to see if you have put original toner, than try to see if the cleaning blade has finished its life and can not clear the drum, than see if the developer need to be changed...
it is from many factors but this you have to check that are can more happen.
Posted on Aug 19, 2010
My copier kyocera fs 9530dn is producing faint copies.What can i do to rectify the problem
clean the main charge corona. hope you haven't been using cheap non kyocera toner or you likey sucked all the developer out of the dv unit. in that case a full maintenance kit would be the best answer. could also be ozone haze on the mirrors or a dirty laser unit
Oct 28, 2015 | Kyocera Office Equipment & Supplies
How to fix dirty copy in np7250
You better upload an image, because there are many kinds of "dirty copy". Also you'll need to check the counters to see if is not the time to replace Developer Unit or Fixing Unit. Check the surface of the Pressure Roller and Heater Roller in the Fixing Unit., also check the surface of Developer Roller if the are scratches or other kind of damage on them. In some cases you need only to clean the printer inside with vacuum cleaner. Be careful not to produce any damage to the printer components. Do not touch Drum surface or Developer roller.
Jan 26, 2015 | Office Equipment & Supplies
My hp laserjet 1300 is is producing faint copies
Usually cause by dirty transfer roller, if your transfer roll look kind of white recommend replace it. Make sure you are using a HP toner cartridge also.
Jun 08, 2014 | HP LaserJet 1300 Printer
Dear Sharp Al-2030 Experts: Paper Copies made from the cover-mounted auto-feed system are produced with a full copy-length thin double line separated by an approximately 1 13/16" wide distance. It is...
There is something on your scan glass. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on. Once the glass is clean your problem is solved!
May 20, 2010 | Office Equipment & Supplies
Produce a dirty copies
Sound like the machine needs a service, The Optics should be cleaned, and adjusted, machine cavity vacuumed out, rollers and belts cleaned, paper feed and fuser rollers inspected. drum and developer checked. Etc, Etc. Once this is done, the copies should be as good as new.
If you need more information, please contact us.
Hope this is of some help.
Ed
May 19, 2009 | Ricoh FT5832 Copier
Copies come out dirty in spots, text is repeated as background.
I have to ask the obvious? have you removed the seal?
If yes, then it's likely just a defect, especially if it's a compatible / remanufactured cartridge -replace it.
Mar 27, 2009 | HP LaserJet 3015 All-In-One Printer
Xerox CopyCentre prints out faint copies. DIrty?
You have a dirty laser, I will tell you how to clean it when I am awake.
Mar 20, 2009 | Xerox CopyCentre C20 Black and White...
Ricoh Aficio 450 Copier Logo
97 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
