Question about HP DeskJet D2330 InkJet Printer
Not install my pc due to lock of cd installer
  • 906 Answers
Link
Above link provides driver of HP Deskjet D2330 depending on what system you are using, kindly browse.
Thank you.
Posted on Aug 05, 2010
While adobe photoshop 7.0 installation, error -115 is coming. Can you please assist me regarding this installation problem.
The probable causes could be due to Data for CD not transfering during the installation.
Here some options you can try,
1. Infected PCs. (Scan PC for virus & malwares)
2. Dirty or bad CD installer. (Use another CD)
3. HDD space for the installation.(Remove some of your data for space allocations)
4. Security Programs running in the background. (Disabled any Security Programs before installations)
5. Too many junk files in your "temp" folder. (Use the CCleaner to clean up your PC and reinstall the program.)
Hope it helps & good luck.
May 13, 2011 | Adobe Photoshop 7.0 for PC
When i install windows xp on dell inspiron 1525 at midle of installation when it restarts an error ocures \r\nthe digital signature catalog D:\I386\sp2.cat coud not be installde. the error code is...
Most likely this is due to a read error from the installation media. This could be either due to a scratched CD/DVD, or dirty CD/DVD drive's lens. Try using another unscratched installation CD/DVD. If this did not help, then try cleaning the CD/DVD drive's lens before attempting the installation.
If neither works, it might be related to a defective memory module.
Nov 28, 2010 | Dell Inspiron 1525 Laptop
I Ball driver CD lost
Dear,
Give us Model of the Cam. we will provide you driver.
Cheers
Jaggu
Sep 23, 2009 | Computers & Internet
Compaq Presario CQ60-104tu
this blue dump screen may be due to many reasons.
the first that we can try is that try the windos installaiton using some another installaiton cd with some upper version. eg if you are trying to install windows XP SP2 then try to install XP SP3 . I am sure it will resolve your problem. Max time this problem is due to the hardware incompatibilty with Operating system. So i recommend you to try some another installaiton cd with upper or diff. version. \ If the problem still continue then its some hardware issue.
Sep 03, 2009 | Computers & Internet
CD Wont eject
Tried in Safe Mode Windows? Worst case is the shut it down, straighten a small paper clip, push it into the small hole on the surface of the DVD-ROM cover (It's a standard to have one). It should eject!
If system will not eject the CD due to a software locked it down, please list softwares the XPS have installed.
May 23, 2009 | Dell XPS One All-in-One TV Desktop with...
During reinstall of XP on Dell Dimension 9100, half way through process the mouse/keyboard locks up and cannot continue with install. Any suggestions? Thanks.
Try using an optical mouse of the latest technology and maybe try a USB key board. Maybe this will make some difference.Try to use the most popular ones for starters...............sodeep
Apr 18, 2009 | Dell Dimension 9100 PC Desktop
Install dvd rom and remove one of the cd rom's
hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.c1c13bc.gifthen pull out cover and you'll cd rack inside your cpu as shown on figureba392e9.jpg release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
Server 2003 sp1 not installing
Plz be posted , in case of server installation - it is veryu delicate the above situation may occur only for the following points .
1.intallation files were skipped by user manually (due to bad CD)
2.Improper Installation (in case root directory contained XP os and installation was overridden windows folder )
3.using a crack patch to OS for CD-KEY.
check and let us know.
Regards,
Sushil
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
Install xp in 3702 tu
TRHERE ARE MANY CONDITION DUE TO WHICH XP IS UNABLE TO INSTAL ON YOUR PC
1.) PROBLEM IN MOTHERBOARD THAT NOT SUPPORT THE XP CONCERN TO YOUR VENDER
2.) HARDISK IS NOT FORMATED PROPERLY FORMAT IT
3.) YOUR CD ROM DRIVE IS NOT SUPPORTING YOUR XP CD
Mar 03, 2008 | Computers & Internet
Cd or dvd rom drive
This might be due to a registry problem. Re-installing windows (OS) or repairing your OS installation can help. You can install from any previous back up or get the installation files in a USB storage device like pen drive.
You can also try the following which have worked .. insert the OS installation disk in the cd-dvd drive. restart Pc. change boot device option. installation of new OS begins. this is a hit n trial method, but has worked earlier.
Dec 27, 2007 | Computers & Internet
HP DeskJet D2330 InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
