Question about GE Dishwashers
After the dishwasher finishes, I notice a green/blue liquid leaking from the bottom of the washer onto the floor. It has a consistency of oil. I have solved this in the past by tightening the screws at the bottom of the washer panel. The leaking is getting worse. Model GSD5500G03WW Serial GH88772BB
  • 90 Answers
SOURCE: dishwasher leaking
need to know the brand and where the leaking is. (exactly)
Posted on Jan 05, 2008
  • 74 Answers
SOURCE: door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Posted on Jan 10, 2008
SOURCE: Dishwasher suddenly started leaking on floor?!
I have leaking from the screws holding the heating element of the same model dishwasher. The part is called heater nuts. I don't know if I need to replace the entire heating element assembly or just replace the nuts.
Any help is appreciated.
Posted on Feb 22, 2008
  • 744 Answers
SOURCE: Water flooding onto floor when running.
The most common cause of this is a loose clamp on the pump discharge hose. It could also be a cracked hose, the hose came off (again, loose clamp). Check both ends - where the hose connects to the dishwasher AND where it connects to the sink drain.
Another possible cause is a bad pump seal, although this is less common, and usually open happens when the dishwasher is pretty old.
Posted on Jan 05, 2010
Testimonial: "Very quick and easy to follow instructions. Thanks."
The problem I have with my LG dishwasher is that a green thick liquid leaks out onto the kick board. I noticed this when the door is half open, I wiped it off but it returns all the time.
Is this ooze perhaps similar to the same color as your liquid detergent or wetting agent (Jet Dri) ? A leaky dispenser would allow these fluids to leak down inside the door where they would continue down and out along the lower door edge. The only other option involves removing the outer door panel to investigate inside the door assembly. There should be no other sources of this sort of material.
Nov 01, 2016 | LG Dishwashers
Could an eroded drain cover gasket cause the dishwasher to leak from under the unit? It is not leaking onto the floor or under the sink, but it is leaking down into our basement along the concrete walls,...
I am inclined to not believe that is the issue. The gasket sits in a basin type of housing. If it was to be a failure, the water would flow into the drain hose and not outside the unit. The most common cause of leaks like this are the main gasket that seals the entire assembly to the tub.
Sep 07, 2013 | Whirlpool Dishwasher White Drain Cover...
GE Nautilis dishwasher has water collecting in bottom while not in use and leaking onto floor approx. 7 yrs old
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Aug 10, 2011 | GE Nautilus 24" Built-in Dishwasher
Leaking on front driver carpet but no visual sign of leaking around door or windows. Carpet is drenched and so is cushion underneath carpet.
1. Have you been using your heater and is the smell sticky sweet? If so you're heater core might be leaking.
2. Have you been using you're A/C? If so you may have a clogged or disconnected condensation drain.
Jan 17, 2011 | 2001 Lexus RX 300
Why is my dishwasher flashing on the eco 45 button
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Water leaking out of the bottom
Sounds like the main bearing has gone bad and that is causing you to loose water on the floor. There is also a rear seal back there that will need to be replaced
May 22, 2009 | GE WSXH208A Front Load Washer
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Pin hole leak in metal under dishwasher
difficult to weld stainloess steel. another way is to drill out the hole slightly and fit a small nut and bolt with fibre washers
Apr 12, 2007 | KitchenAid 24 in. KUDI02CR Built-in...
Dishwashers Logo
89 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
