Question about Carrier LCA061P Air Conditioner
I own a Carrier LCA061P air conditioner that drips condensed water on the foor beneath the window it is mounted in. I tried purposefully to install it with a slight downward slope outside the window, to no avail. Is this condensation normal, and how is the unit supposed to evacuate it properly?
    President:
  • 2,468 Answers
Make sure the drain holes outside are not plugged,some water is retained by the unit to cool the compressor,but too much water will build up and drain inside
Posted on Aug 05, 2010
How to properly install my carrier siesta air conditioner,seems to build up condensation that wont evaporate ,justwant the proper installation diagram ,orhow to do it yourself kinda video
condensation doesn't evaporate
it runs off the evaporator fins into a drain channel and out side
it is possible that the drain is blocked
the action of an air conditioner is to remove the humidity (condensation from the room) and drain it outside
if it is to evaporate then the purpose of the air conditioner would be defeated.
Jun 30, 2015 | Carrier Siesta II TCA101B Air Conditioner
Want to know how many btu lca061p
6050BTU
Carrier LCA061P 6050 BTU Thru-Wall/Window Air Conditioner
Jul 11, 2012 | Carrier LCA061P Air Conditioner
I have a carrier visionaire model LCA061P and i am in need of the fan assembly or part # for it it. any help would be appricated
Something fell from the roof and broke the top (outside) of my
visionair a/c unit. Can I replace the part? It's near the circle on
top and finally part broke away and can't be found
Smurfsters@aol.com
Aug 13, 2010 | Carrier LCA061P Air Conditioner
Is it normal for a car to drip water on the ground after running the air conditioner?
Yes, The air conditioner evaporator core inside the vehicle is very cold when the a/c is operating and moisture will condense on the outside of it, especially on a humid day. This moisture then trickles down the sides of the core and collects in the plastic housing beneath the core where it then escapes through the evaporator housing drain tube and drips on the ground beneath the passenger side of the chassis. The more humidity in the air the more moisture you will see dripping onto the ground. If the little drip hose should ever get plugged up this water then will overflow the housing and drip on the passenger side carpet so if you ever have that problem you'll know what the cause is.
Jun 17, 2010 | 2006 Chevrolet Trailblazer
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
My AC unit is a carrier LCA061P window unit. It works okay but has recently started to make a loud clatter. I would like to replace whatever parts that are needed but can't seem to find any relevant...
Good possibility. WIth the unit powered off and unplugged check the clearance of the wheel and the collection basin underneath, Debris could be the source but I suspect the bearing is failing on the motor
Jul 16, 2009 | Carrier Heating & Cooling
Carrier LCA061P Air Conditioner Logo
159 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
