Question about Indesit W 123 Front Load Washer
Dear Expert, My W1XL123 has just started to show a fault. The cycles 2, 3 & 4 do not appear to complete a full cycle including maybe rinse but definately spin. The light flashes faster than it has done in the past and I can open the door to retreive the washing. Before doing so I give the was a spin only. This is not ideal. I have tried turning it off at the wall and then back on. This hasnt helped. Any advice please. Its not an old machine and still in very good condition!! Kind Regards Judith Howe
SOURCE: Washing Machine not draining
same thing happened to me but the obstruction was in the hose at the back of the filter and coudnt be seen in the filter. i paid 150euro to engineer to fix this. i watched him fix it and can do it myself now. they rob you for something that is so simple to fix.
Posted on Sep 26, 2007
wagdom
  • 64 Answers
SOURCE: indesit wg1130t front loader washing machine
maybe the drive belt is off/broken. Take the back off to check
Posted on Oct 31, 2007
SOURCE: Indesit 1000 cycle starts but then lights flash
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
Posted on Jun 13, 2008
kjmac
  • 97 Answers
SOURCE: Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Posted on Jul 31, 2008
SOURCE: Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Oct 15, 2009
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Wh60f60w1
Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle.
For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water.
This is how I sorted the machine: -
1. I turned off & unplugged the machine.
2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine.
a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry.
b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there).
3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :)
4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door.
I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so.
This may have just saved me a grand$ :)
Good luck.
cheers
Monkeyboy :^)
Apr 28, 2013 | Washing Machines
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
Have a shu 4322 dishwasher it fills with water and drains but the spray arms do not spray. have not tried anything yet.this dishwasher is not hooked up. it was given to me by a friend who replaced all his...
Welcome to FixYa.
There was indeed a recall involving the control replacement nearly two years ago now if I recall.
As for checking into the present issue ( it doesn`t sound like anything to do with the control based on your description ) it sounds like the pump impeller may have become stuck. Did the dishwasher sit idle or in storage unused for a period of time ?
I have a service bulletin I could send you via email regarding remedying that issue of stuck impeller if you contact me at macmarkus@live.ca
I`d suggest you run the dishwasher through a diagnostic, but either procedure will require hooking it up.
To do this test/diagnostic on the SHU4322 series machine, it is as follows...
To start test program, press and hold both REGULAR WASH and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ "20" = version 0 without jumper).
When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone).
Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start button is pressed.
To start testing, press both the REGULAR WASH and RINSE & HOLD buttons a second time.
When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ "6" = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
2 = Heating fault
4 = Filling fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
i.e.
If water level switch has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch has failed (opened), display will show "0", water won't heat (to 150?F) and water won't stop circulating. If NTC probe has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating.
What needs to be done to solve the problem will depend on the results/findings of the dianostic, so let me know what you find and we can go from there.
Either way keep me in the loop and I`ll assist you the best I can. Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Oct 10, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Controller, door interlock and motor replaced. Unit comes on, but does not operate.
Hello Dave,
Welcome to FixYa.
Try this test I posted below and let me know what error you find...if any.
To begin the test program, press both the SCRUB WASH and DELICATE/ECONO wash program buttons at the same time
as you turn the unit on by pressing the ON/OFF button. Initially, the control unit version number will appear in the display
(e.g./ 20 = version 20, 21 = version 21, etc.).
When the wash program buttons are released, the LED's above them will begin flashing. To end the test program or test cycle, press the ON/OFF button.
To check the wash program LED, press its corresponding button.
To check the Cycle Countdown display, Refill Rinse Agent LED and REGULAR WASH button LED, press the REGULAR WASH button (press the DELAY START button to test the
The Cycle Countdown display should show "88" when the DELAY START button is pressed and "8h" when the REGULAR WASH button is pressed.
To start the test cycle, press both the SCRUB WASH and DELICATE/ECONO buttons a second time.
When the test cycle has completed, the Cycle Countdown display will indicate a fault using the codes below. If a combination of faults exists, the code numbers will be added together, (e.g./ 6 = faults 2 + 4).
0 = No faults
2 = Heating fault
4 = Filling fault
email me at macmarkus@live.ca and I can send you via a "pdf" of the diagnostic/repair manual for your specific Bosch...provided it is indeed a SHU5316 unit.
I`ll watch for your reply. Good luck.
Regards,
Macmarkus :)
Sep 30, 2010 | Bosch SHU5316UC Dishwasher
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Fault light flashing,
Is it please possible for you to add additional comments in your query about dishwasher problem
1. make and model number of dishwasher
2. are there any fault codes or lights showing up - which ones
3. at what cycle does the operation stop - eg still washing and there is water in dishwasher - is it warm/ cold, rinse is starting (can hear the pump) but stops halfway, rinse is complete but does not dry..
4. how old is the unit
clarification on above will help understand the problem better.
Jan 03, 2010 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
together, (e.g./ “6” = faults 2 + 4).
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
