Question about Sport & Outdoor - Others
I have a Toro 616Z Zero Turn Lawn Mower. It has Turf Tires on the rear. I have two questions. #1. Does anyone know the size of the wheel for a tube? (Noticed the tire is flat last night and pumped up but it is flat again. It has a tube. #2. I've noticed that the mower really tends to tear up the grass when on any kind of slope or on turns. The rear tires rip the grass out by the roots. Horrible if grass is the slightest bit damp. Is this normal? Thanks Terry...
  • terry_battel Aug 05, 2010
    Thanks for the good advise. I'm sure this will help.
    President:
  • 2,468 Answers
First the tire is leaking around the rim bead area get the tire size and go to a tire supplier and they will get you the right size tube,this leakage is normal due to the very low air pressure run in these turf tires,secondly the reason its tearing up the grass is because the tires are squatting and this creates a twisting of the sidewall of the tire and leads to the tearing action,try about 5 lbs higher air pressure and see if this helps
Posted on Aug 05, 2010
  • 1 more comment
    Thanks for the quick response. As I mentioned, the rear tire has a tube in it already. I bought this mower used about 8 years ago and it must have been installed before that. I was just looking to see what size tube replacement I would need raher than get a new tire. The rubber is still in good shape. Once fixed, I'll give the increased pressure a shot. It is supposed to run at about 8psi on the rears so I will increase to 13.
    Ps. I couldn't read the tire size on the sidewall.
  • danny Hendrickson Aug 05, 2010
    call a toro dealer and they can look up the correct size tire/tube combination for you, or possibly check the opposite tire or opposite sidewall on the inner side,it may not have worn off yet and the size may be visible,also "FREY"lube makes a great bead sealer when I was in the farm tire installation business also farm and fleet carries a tubeless tire sealer that sprays in through the valve stem also,if this helps great and if possible rate this...info..Thank You.Dan
How do you push a toro riding mower
riding mowers have a bypass system to be able to move a machine that's not running. At the rear of unit you will find a heavy wire coming out the back end lift a little and pull this out. you should now be able to push unit
Oct 18, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How do I fix a rear wheel that's locking up on my Toro zero turn mower?
Replace axle or check to make sure everything is still good and greased
Jul 24, 2014 | Toro TimeCutter SS4260 - 22HP 42 Zero Turn...
Toro zero turn mower wont move
there is a parking brake turn it off if that still dont work check your hydrolic lines
Jan 21, 2014 | Garden
Toro zero turn mower has no drive power when I engage the transmission arms. very slow or no wheel turn.
Check the hydraulic fluid level first. Have you had the fluid and filter changed? Jack the rear tires up and support it with jack stands. Start the mower and run the wheels forward and backwards for about five times each. This will bleed any air that may be in the lines. Lower the mower and try it again. If it doesn't work, look at the condition of the pump belt. Is it slipping? Is it glazed looking on the side of the belts? If all looks good, then you will have to have the pumps volume tested at a local shop. This requires specialized tools to perform a flow test. If they fail the volume flow test, then they will have to be replaced.
Sep 07, 2013 | Toro Garden
TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Apr 13, 2012 | Toro 60'' Zero Turn Lawn Mower Enclosed...
Sport & Outdoor - Others Logo
100 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
