Question about General Electric GE 24-Hour Timer, 2-Pin #15004
My Ge Mechanical Time Switch (Model number 15087) is losing time. Is there any way to adjust the timer so that it keeps correct time?
There is no adjustment if timer clock is running slow.
Timer clock motors run slow when the motor starts to fail.
There are no replacement clock modules this timer.
Buy a new timer at Home Depot, and swap out insides of timer using 1/4" hex nut driver, and then return defect timer in new box.
http://waterheatertimer.org/GE-timers-and-manuals.html#15207
Posted on Oct 05, 2011
Set clock on ge profile gas range
Didn't give a model number, but try the following:
For a mechanical clock, push the center knob in and turn the clock hands to the correct time. (If the Minute Timer pointer should move also, let the knob out, turn the Timer pointer to OFF.)
For a digital clock, push in the center knob of the Minute Timer and turn Knob in either direction to set the Digital Clock numerals to the correct time.
For an electronic clock, touch the Clock pad. Touch the number pad. Touch the start pad until the time of day shows in the display. Note: On double wall ovens, you can only set the Timer for one oven.
(From the GE website)
Nov 06, 2016 | GE Kitchen Ranges
Set the hour on clock on GE electric stove
Where to purchase trippers for GE mechanical time switch model #15163?
This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f415602webg2.jpg
Jul 03, 2014 | General Electric GE 56941 24-Hour Outdoor...
Instructios model #1508
That timer does not appear in my files, under Noma, or under 1508, or under any other brand.
Nor does N1508
There is N1507, N1502, N1506,
Copy following link to identify same-similar timer and download possible manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html
GE makes many timers with 15xxx product numbers:
Including: 15087, 15086, 15081-4, 15088, 15089, 15086
Add a comment and describe timer in detail for possible additional assistance
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 03, 2012 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I need help to install pool pump to mechanical intermatic timer switch GE to replace the digital control.
Question is not clear.
Add a comment with missing information for exact wiring diagrams.
Voltage is not known.
Timer model numbers are not known.
You have two timers.
You are replacing unknown electronic timer with unknown mechanical timer.
Intermatic timers and GE timers are different companies, and each makes many different timers
Each box timer has identification on inside of timer door.
Open following links to help identify timer and see wiring diagrams.
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 14, 2011 | Intermatic T104 24h 208-277v Mechanical...
Brand new Woods Timer (Model 59730) turns on/off correctly, but completely stops during "off" hours every day. When I reset the current time, it runs for about 8-10 hours, then stops. Returned...
It seems odd that you'd get two defective timers.
I bought one of these timers from Home Depot under the GE brand and the dial rotates correctly as time passes.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
Woods 59730/ GE 15107 timer is a mechanical timer, so circuit problems should not affect clock motor.
On electronic timers, if circuit is not clean (circuit has ground fault), then timers don't last long and do peculiar things.
My suggestion is to try timer on indoor plug, on a different circuit breaker, for 1 day and see if it keeps running.
This will tell you if outdoor plug might have a loose wire, and that electricity is getting cut off.
Add a comment and tell me what you discover, or add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Hardware & Accessories
Timer wheel seems to slip. Won't hold time
You posted under Intermatic T104 timer.
If you have different timer, information below may not fit your timer.
Add a comment with correct timer brand and model number.
1) Click manual override on-off to see if Load turns ON, and that override snaps crisp and clean and is not sluggish or hard to move.
If override is not functioning well, then timer is bad. Buy new timer.
2) If dial is rotating, note current time, and watch if dial is keeping correct time over full day.
If dial is running slow, then buy T100 series 240Volt clock motor for T104 timer.
3) If dial is keeping good time, then tripper might be worn and need replacement
Link below shows Intermatic T100 series parts:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
4) Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer, or any do-it-yourself project.
Jan 06, 2011 | Intermatic T104 24h 208-277v Mechanical...
How do I set a general electric outdoor timer
If I understand you correctly, you have GE outdoor box-type timer, for example the GE-15087. If this is the wrong timer, please respond with model number and I'll look up the information.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
http://waterheatertimer.org/How-to-wire-GE-15087-timer.html
6888635.jpgSegment up, timer on segment down, timer off
GE has additional manuals
http://www.jascoproducts.com/support/manual-downloads/index.asp?search=timer&submit=Search&offset=-1
Oct 19, 2010 | General Electric Hardware & Accessories
How to wire this ge timer 120v
Open following links for GE timers and 15087 wiring:
GE box timers can be wired many different ways to control single-loads, multiple loads, 2-speed motors, 120V, 208V, 277V, 240V, 440V, 24V.
Add a comment and say exactly what you are wiring, and what voltage you are using for more information.
Dec 07, 2009 | General Electric GE 56941 24-Hour Outdoor...
General Electric GE 24-Hour Timer, 2-Pin #15004 Logo
342 people viewed this question
Top General Electric Hardware & Accessories Experts
Marvin
Marvin
Craig Butler
Craig Butler
ray gallant
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
