Question about Craftsman Garden
I have a tecumseh 6.0 sears craftsman it has gas in the oil what do i need to do to fix it
  • Craftsman Master
  • 7,482 Answers
It sounds like you float needle valve is stuck open and allowing gasoline to drain into the oil sump.
Sounds like you will need to clean your carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me,
Thanks
Good Luck,
I hope this helped
Posted on Aug 11, 2010
How to start gas powered snow blower
A model number and serial from the engine would help. Also the manufacturer if its Briggs or tecumseh
Nov 09, 2013 | Garden
Pull starter rope craftsman 358-791050
there should be 4 bolts holding the pull rope and spring to the motor if you need more info. go to Sears Parts.;co.com
Aug 20, 2017 | Craftsman 25cc Gas Line Trimmer
Kicking braker out
Check valve is bad creates high head preasure. $12-14 + shipping. Go to sears web sit to find part on diagram. Takes less than 30 min. to install. I had same problem a valve fix ed it.
Nov 19, 2010 | Craftsman 33 gal Air Compressor 6 hp...
Bought a used Craftsman 9/26 w/ tecumseh engine. Mixed or not?
Add the gas! No need to put oil into gas unless it is a two cycle, which I doubt. Have fun...Lee
Jan 20, 2010 | Craftsman 16" High Garden Tractor Snow and...
I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 07, 2009 | Craftsman Garden
Sears craftsman 6hp chipper-shredder FLYWHEEL.
Go to Lowe's they will found the part for on the computer and will tell you where it is at in the store!!
Oct 12, 2009 | Craftsman Gas Mini - Tiller/Edger
4HP Tecumseh flat-head head-bolt torque?
check the numbers on the motor and you can contact Tecumseh or check their website for info, they are usually very good with their help
Jun 29, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Pressure regulator gauge wont work on my 3 gal. air compressor how do i fix it or where do i get a new one (craftsman) i also lost my book , how often do i change the oil ?
If the regulator is inline you need de-energize the compressor to remove the regulator.
Sears parts and service:
http://www.sears.com/shc/s/c_10153_12605_Home+Services_Repair+%26+Maintenance?adCell=W4
Compressor Information:
http://www.sears.com/shc/s/c_10153_12605_Tools_Compressors+%26+Air+Tools
Wiki Buying Guide for Craftsman Regulators:
http://www.shopwiki.com/search/Craftsman+Regulator+with+Gauge
Sears / Craftsman Forum & Repair Information:
http://www.sears.com/shc/s/nb_10153_12605_NB_CSHome
3rd Party Regulator Retailer:
http://www.controlair.com/
If you feel that your problem is too serious for you to repairyourself, please contact a licensed/certified technician.
If you wish,you can call Sears HomeCentral at 1-800-4-MY-HOME tomake an appointment for a technician to visit. (There is a charge forthis service.)
Mar 11, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Garden Logo
119 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
