Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite refrigerator, french doors on top, freezer on bottom. refrigerator light goes on when the doors are closed and doesn't always come on when the doors are opened.
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
  • 2336 Answers
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
  • 66 Answers
SOURCE: refrigerator not cooling
This could be that it is out of balance. Set the temperature settings to midway. This control can easily get the fridge temp out out of balance if over adjusted. If you already have the tmp control at midway then you need to make sure there are no obstructions to the duct that carries the cold air from the freezer to the fresh food section to cool it. Check for ice buildup or any kind of blockage. Let me know what you find.
Posted on Nov 16, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
blueextc3221
  • 15935 Answers
SOURCE: Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
The light is remain lite and the plastic cover is malted.
The switch at the bottom of the door is bad, not turning the light off when the door is closed
Mar 01, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
I have a 2006 kenmore elite trio refridgerator wirh french doors and bottom freezer. on of the door handles is loose. what tool do i use to tighten handle. each handle has a screw at top and bottom. The...
There is two allen set screws for each hand at both end and they are facing each other on the handles.. Remove the allen screw and put a very minute speck of jelly on each screw---small-small amount. This will kept the set screws from loosen up. GB...stewbison
Aug 31, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
My Kenmore Elite french doors bottom freezer drawer fridge has condinsation in the top of my fridge what is causing this?
bad/dirty door seals allowing fresh moist air in.
Sep 24, 2009 | Kenmore 24.8 cu. ft. Trio French Door...
Kenmore elite bottom freezer icing up
if it has an ice maker fix or adjust the over flow for the ice try.
Jun 18, 2009 | Zanussi ZEBF250W Bottom Freezer...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
