Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
Icemaker kitchenaid kuia18pnls2 isn't making ice and is hot on inside when running. i have run it through clean cycle three times. no ice
    President:
  • 2,468 Answers
If the whole unit is warm,then its either the ptc overload on the compressor that's bad or the main board in the rear area of the unit is bad and needs replacing
Posted on Aug 05, 2010
Reset the ice maker back to making ice again
Turn the water supply off to the fridge, make sure the bailer wire (ice level bar) is in the down position. let the Ice maker run thru its cycle. When the cycle is complete the fingers that push out the cubes should all be down. Unplug the fridge for about 5 min. During this time turn the water supply back on. Plug the fridge back in and let it run thru a few cycles. This should reset the icemaker cycle. As a note: you should be able to hear the water turn on with a solid thump as the valve opens to fill the cube trays inside the icemaker.
Sep 18, 2014 | Samsung Refrigerators
Icemaker Kitchenaid KUIA18PNLS2 water won't run over the chill plate.
Replace the recirculating pump, that pump must run to bring water from the reservoir to the chill plate. A quick teat for you, Turn off unit wait 2 mins, turn back on, tat this time the unit should fill for a minute, run recirculating pump for one minute, fill again 1 minute, than run compressor with the recirculating pump. Anythings fails at this point the component will need to be replaced.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 16, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
Icemaker making noise
check that there isn't any ice stuck inside the icemaker teeth.
Apr 24, 2012 | Whirlpool Ice maker 4317943
I have a KitchenAid Side by Side with a stubborn ice maker (modular). It seems to make ice, but it won't complete the full harvest cycle for some reason. I can mess around with it (basically warm it...
Hello Tom,
I see where ya said the water dispenser works good and thats cool! when you do get the i/m to run the ice harvest cycle are the cubes full size? if yes the water supply can be ruled out as a possibility. Besides the water not seeming as cold are other things in the fresh food compartment NOT as cold as they are not as cold as in the past,if yes try removing the grill below the doors and clean the dust from the coil there,if it isn't there its the rear of the ref. by the compressor. One of the first things to be affected when a ref is working hard to keep things cool due to a dusty coil is going to be the icemaker,it will freeze the ice but the internal thermostat inside of the i/m module isn't satisfied its cold enough to start the harvest. When jumping out the T&H what exactly your doing is jumping the t-stat regadrless of the temp. of it ,causing it to run a harvest cycle
I hope this answer helps you,
Gene
Aug 05, 2011 | KitchenAid KSCS25FKSS Side by Side...
Run cleaning solution through kitchenaid free standing icemaker (KUIA18NNJS5) and then left it off for a week while on vacation. When we came home turned on and will not make ice. Gets cold but no water...
reach inside the sump where the water is stored. you can feel the pump in there. turn it on and see if you feel water moving. there is a clear plastic hose that falls off of the pump all the time. the hose clamp is kind of weak and the pump can blow it off sometimes. Just put it back on, or get a better clamp and reinstall it. APDEPOT.com is the best place for parts.
Jul 19, 2011 | Refrigerators
Did a cleaning cycle and afterwards turned the unit on, however when the on cycle is depressed the cleaning light comes on and it begins to both make ice and clean. The condencer runs but not enougth water...
manually drop hot water inside the freezer area, the freezer area have a little hole with a pipe laying to the tray down. as for as i concern the drainage pipe is closed due to ice. but if u drop hot water inside the freezer area it will unblock the pipe. and the friedge will work better then before..
good luck
shafky
Jun 19, 2009 | GE Monogram ZDI15C Automatic Icemaker
Icemaker stuck in 'vacation mode'
Feel inside the ice slots are there any old cubes that have evaporated in time? Take the ice maker out and clean it up and place it back inside to see if it will fill with fresh water. Take a hair dryer and melt the old ice inside the slots and see if it will try to fill. I will wait for a response from you.
KSCS25INWH00 Kitchenaid Parts
APPLIANCE 911
KitchenAid Refrigerator Ice Maker Assembly 2198597
May 06, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Kitchenaid stand alone ice does not make ice feel heat inside bin
Either has electric problem or mechanical.
way to tell is plug it up, turn it on turn on water. If its sending in water unplug it and if water stops it is electrical and the ice maker head is causing the problem if it stops the water valve is stuck open and you can disassemble and clean it out sometimes. A slight lime scale can cause this.
Hope this helps please rate me accordingly and good luck.
Mar 12, 2009 | KitchenAid KUIS18NNT 18" Automatic Ice...
Water overran ice maker tray
It could be one of two things. The fill cycle could be too long causing the water to overflow or the icemaker may not be ejecting all the cubes out of the tray. A normal fill cycle is very short. Maybe 6 seconds long. So I would check and see how long the fill cycle is and when it stops check and see how much the tray is filled with water. I would also check and make sure that all the ice cubes are ejecting next time you hear it harvest.
Jul 12, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
192 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
