Where can I find info simple enough to describe how to scroll up and down with a laptop. I have an old desktop and switching is really hard for an old lady
Usually easiest to scroll page up or down on laptop is to use arrow keys on your keypad - arrow up or arrow down. You'll find also keys "pg up" and "pg dn" for that. "Home" takes you at once to the top of page and "end" all the way down to the bottom of page.
Hope this helps you and answers your question. Have a nice day :)
Posted on Aug 05, 2010
Look ip address subnet mask default router modelwrt54g
If you have your desktop or laptop Click on start, in the run box typ CMD
A box will appear, At the end of the C:\whatever it says
Type ipconfig /all
IT may scroll by you but use the scroll bar to scroll up and read the lines that you need. You laptop or desktop will need ot be using the same router when you use this test.
Just read the lines and write down the results and transfer that info to the Dish network setup.
Oct 15, 2013 | DISH Network Televison & Video
Toshiba Satellite A205-S5825 graphcs upgrade
This is a laptop correct?
If so you cannot upgrade laptop, Unlike a desktop the graphic's processor is built into the motherboard.
As for the CPU it is most likely also incapable of upgrade depending on most of almost all laptops
Laptop's are pretty much incapable of upgrades. (excluding RAM and HDD drives)
Mar 01, 2013 | Toshiba Satellite A205-S5825 PC Notebook
My asus k53e charger port is broken well it still works when I put some force on it but it seems as if the charger port is pushed in and the charger can't reach please help I need to use my laptop and
Hi,, this is a very simple problem but the fix for it is or can be very hard. depending on your skill set you can try to attempt the repairs as I will describe below, but you should really consider getting it professionally repaired.
The problem is the charge port. Quite often the solder holding the contacts is broken and causing it to short out and sometimes the pins in the port are broken as well.. This fix is as simple as re soldering the port or replacing it..
1.) Follow the instructions on this likn to disassemble the Laptop and get to the charge port. http://www.ifixit.com/Guide/Disassembly+guide+for+Asus+K53E+laptop./10166/1
2.) re solder or replace the port.
General Disclaimer
Please note based on the information given i have made my suggestions, This can be wrong as I'm not there in person to verify it therefor i can make no guarantee that is the problem. I strongly suggest you have this problem professionally looked at.
Dec 27, 2012 | Computers & Internet
HP DV7-3085DX Shut down at 120 degrees C
No solution, but that is really hot. Hot enough to start frying other components. Eventually it will.
Nov 28, 2012 | Computers & Internet
Its a bit hard to describe. When I scroll down to read its like the top part of the email or words on a forum also move or shift. I can read fine, not blurry but the whole page moves and then stops O.K. so...
This sounds like a problem with the amount of graphics memory, Do you have problems with video playback?
Have you the most up to date display drivers?
This is not an easy problem to diagnose without your complete system specs, you may get a better answer if you can give more info on your PC setup
Oct 11, 2010 | Computers & Internet
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
How can a transfer my info from a broken computer to a new one?
You need to purchase an external enclosure and install the old laptop hard drive in it. Then plug it into your desktop and copy the files .
Buy it here:
http://www.cyberguys.com/product-search/?keyword=hard+drive+enclosures
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | Computers & Internet
New hard drive on old e-machine. "No operating sys"
First of all did you install an operating system on your HD like windows or linux, copied doesn't work really good, take out the old HD for the new one and install the operating system. You can always afterward copy your old data on the new one
To enter into Bios puch "del" "F2" "F5" and "F8" simultanously (depend on the bios) when in bios go in BOOT menu with left or right arrow. then go down on the new hard drive and put it on top of the list, usully with F5 and F6 (how to use the menu is describe on the right), then press F10 and "Y" (yes) to accept the modification...
good luck
Dec 19, 2008 | E-Machines eMachines T3830 PC Desktop
Mic problems
http://www.kellys-korner-xp.com/xp_abc.htm click on s and scroll down to Sounds.....
I have Sigmatel too. try this website. I have been working three days on my computer. i tried new drivers (said i didn't need them. i actually went to a message board where people had a similar problem and downloaded (clicked on) a patch (3 small zipped files that were registry keys). It was really scary to trust a two year old message in a message board from a stranger but it restored my sounds instantly. I did back up the registry first. I had deleted codecs (xvid) that i never used and my system sounds disappeared. If this doesn't work, keep googling phrases and look for message boards. good luck
Jul 24, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
Alun Cox
David Payne
David Payne
