Question about GPS
On '02 reg Renault Scenic diesel, when climbing a hill with the car loaded, the "heater plugs on" lamp lights and the engine loses power. Can still change down and continue. Once over hill, light goes out, normal performance.
    Brigadier General:
  • 7,191 Answers
Kindly submit the question under the Renault cars section on the website by clicking this link so that the top car experts can view and provide a solution to the problem.
Thanks for using FixYa
Posted on Aug 05, 2010
Why does my 98 dodge caravan have trouble climbing hills?
A transmission issue would give vibration tremendously during uphill. If you're not getting the vibration, or burning smell of transmission fluid, suspect clogged catalytic converters.
May 09, 2014 | 1998 Dodge Caravan
Renault scenic cooling system
you must check you thermostart and have it replaced and check you heater relay it mu=ight be malfunctionng as well
Dec 18, 2013 | Cars & Trucks
Renault scenic overheating and heater blowing cold air
put a radiator flush in the expansion bottle .to clean the core of both your radiator and your heater. core will have dirt or rust .run the car for about 20 miles.then drain it .refill with 50/50 mix of anti freeze.now heating on full leave the cap off .turn over the engine,on tick over.push in the rubber hose with finger and thumb to remove the air out the bottle.then refit the cap.
Renault megane scenic
The check engine light means something is wrong in your car or ecu. You should visit Renault to see what\'s going on with a PC diagnostic tool. The other light is a sign the diesel heaters are preparing before starting the engine. But you definitely need the diagnostic tool with the right cable to check your ecu for faults.
May 20, 2013 | Cars & Trucks
Can MAIN PREHEATER RELAY do problem with power on renault megane 1.9dti
Not sure what your asking here as your english is more polish but i think you mean the cold start pre heater relay for the glow plugs or heater plugs and yes i have had this problem where the light in the dash is on but the heater plugs are not on and this just a warning light fault in the unit and is not a cause of loss of power but a faulty EGR valve will cause this so make a blanking gasket to seal the valve off and iam sure this will cure it -?-? but be carefull here with the diagnostics with these lovely french cars as a faulty throttle pedal control up under the dash will cause loss of power and lots of weird things with the engine light and the heater plug warning light ,these renaults are a rule unto themselves and although mechanically superior to most vehicles the electrics and the diagnostics leave a lot to be desired by this manufacturer
Sep 29, 2012 | 1999 Renault Megane
I have a renault scenic and the heater plug light keeps going on and off and i lose power what could this be thanks
it means that u have an engine problem and it goes into limp mode thats why it looses power
Apr 13, 2010 | 2003 Renault 181
Y reg scenic misfiring
if the car isnt diesel well then that would do it.you need to drain your fuel system and tank and would be good to change plugs too.
Feb 07, 2010 | 2000 Renault 181
Renault espace 02 reg diesel 2.2 heater fans not working control switch working
tipical espace, it wont work or only works on full speed is usually the problems. its the heater resistor, usually a thermal fuse goes on it which can be brought from maplins for 95p.
Nov 07, 2009 | 2002 Renault Sportwagon
My Renault Megane Scenic S reg heater is not working
Most likely to be a faulty resistor block, which has 3 resistors and a thermal fuse controlling fan speeds 1,2 and 3, maximum speed 4 by-passes the resister block. It may also be poor electrical connections to the resistor block caused by overheating. Renault ask for approximately £350 to carry out repairs, a replacement resistor block will cost £50. If you decide to carry out the repairs yourself, be advised that if you are not competent to carry out such work you, could cause electrical damage or worse an electrical fire.
Oct 24, 2009 | 2004 Renault 181
Renault megane scenic 1.9 dt r reg 1997 cold start problems
This being a diesel, lack of compression is your worst enemy. These symptoms sound like a blown head gasket. Check your coolant for signs of oil, and check your oil for signs of coolant. (oil will be milky looking) Also indicative of a head gasket problem is an oil or coolant leak from the engine as well. If you see no evidence of the above, have a compression test done, and it should show up.
Oct 20, 2009 | 1986 Renault Sport
GPS Logo
27 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
