Question about Sony CFD-ZW155 Cassette/CD Boombox
My Sony CFD-ZW155 will not play cds. When I put in a cd, or even the disc lens cleaner, it will not spin, sometimes it will move a fraction of an inch, but then it always reads no cd. So, I don't "think" it's a lens problem. Also the round disc shape part that is attached to the lid seems loose. It looks like it applies pressure to the cd, holding it in place to spin. Any suggestions? and how do I get in to the cd player case?
  • John McVey Aug 05, 2010
    No, I fixed it myself. Thanks.
  • 677 Answers
Hi, it's the motor that controls the lens that is bad and that makes the cd play.you will need to replace the motor it will work fine.
Posted on Aug 05, 2010
    Thanks, well, before I got your answer, I took a micro-fiber cloth and wiped off the lens. It also seemed to move the lens around a little so maybe it was stuck.
    Put in a cd and it played! I then ran my disc cleaner and it's playing right now as I type.
    Thanks for your input though. I hope it doesn't come to any more repairs.
Sony boom box model# CFD-So1 serial# 2813391 The CD part says there is no disc in. I tried several DISC WITH NO LUCK. Please help
This error "disc error", "no disc present" or " can\'t read cd". This all error are related to lens problem. If the lens is dirty or if the lens is got cracked or if the lens is getting blocked then it can happen. The lens is very thin glass material. You can say the lens is the "eye" of the unit. If the eye is dirty then it will not see the object. The unit needs to be opened carefully and this lens has to be checked. If any dust is collected clean it. Using the cd lens cleaner helps, but if the dust is got stuck hard or if its any other internal part then the lens cleaner will not help. If the lens is got cracked then the lens assembly has to be replaced.
You can use dry tissue to clean the lens. once the unit is opened. ------------ ------------- In most of the cases, this problem is not related to cd.But still get the cd checked in any other player too, this will confirm the fault. Also try other various cds in the boombox cd player and confirm. But if the cds not playing in other player too then its faulty cd.But this is very rare. Most probably the fault is related to boom box cd player. In the boom box cd player unit there are two main parts. One is cd spinning motor and other is cd reading lens(its also called "EYE" of the cd player).But many times the cd spins internally and does not play. If you can hear the noise of cd spin inside then its lens problem and not the motor. But if there is no spin noise in the unit then both lens and motor are to be checked. The motor is not spinning because its short/blocked or its connections are got loose. It has to be checked. The lens is not reading the cd, because its got dirty or its got cracked and faulty. The boom box cd player lens is made up of thin glass and its very delicate. Many a times dust gets collected on the lens, so the lens stops reading the cd and it do not play. Some times there is no dirt on lens but it gets cracked, if by mistake any pressure is applied on the unit or up-side down cd is placed in the tray or internal short circuit has occurred. These are few possibilities of lens not working. But in most cases its dirty lens causing this problem. SO open the tray by pressing the eject button, then unplug the unit from main power outlet, by keeping the cd tray open. Then take air blower and blow air in the unit. Please remove, if there is any cd in the tray while blowing air. Just blow air for few minutes. Then take a dry tissue and clan the cd placing tray externally and then reconnect the power and see, if that is helping or not. If the problem is same as before, then disassemble the unit and clean the lens manually by hand using dry tissue paper and then see if its helping. But take care while cleaning the lens with dry tissue you doesn't apply too much pressure on lens or any other parts. Also before removing any screw to disassemble the unit. Take a marker with you ready. Just mark the position of parts and screws before removing. If you have a cell phone with web cam in it then take a photo of the internal parts before moving any parts. Disassembly is not very hard but reassembling is not easy. So this pictures and marks with help you for reassembly. ----------But if lens is cracked internally then the lens assembly has to be replaced. If motor wires are loose then you can easily get it re-soldered by soldering machine. You can get it replaced from local cd /dvd player repair center. They have these parts with them. --------------- This should help. Thanks. Helpmech.
Aug 06, 2011 | Sony Boom Box With CD Player & Cassette...
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
Sony CFD-F10 wont play cds, says no disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it say "no disc".
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
Feb 14, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
Philips mc235B/37 CD player no longers plays CDs. I get a "No Disc" error or an "Error" message. CD's often don'teven spin. If they do, they spin slowly, then stop, and start spinning in reverse before...
if you can see the laser then gentaly with a soft cloth wipe the lens
and then try
if that doesnt work then i recoment that you call philips and see what they say because it is slightly older than one year they might replace it for free
if not call the shop that you bought it from
May 09, 2010 | Philips MC235 Shelf System
My CD player says "no disc" when there is one in or else "error" and doesn't play or plays a few songs then goes to "no disc".
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it says "no disc".
Good luck.
Apr 23, 2010 | Sony CFD-646 Boombox
My sony cfd zw155 will not play cd's they start to revolve and then stop and display reads no disc
The internal laser lens might need cleaning due to dust build up with a CD Cleaner or the Lens has Become faulty but most of the time it will be a dirty lens
Apr 03, 2010 | Sony CFD-ZW155 Cassette/CD Boombox
My sony CFD-E100 won't recognize CDs
use a cotton swab to clean the optical lens-which is seen by opening the CD cover. if after cleaning the lens it still doesnt play a cd - exercise all manual switches(could be a dirty cd/radio switch), several times. after these steps, and the cd still refuses to spin...its hopless. the optic is bad.and not economical to repair. bet the cotton swab does the trick.
Mar 04, 2010 | Sony CFD-E100 Boombox
My CFD-Z501 won't play a disc. I get the message "no disc"
Try to use CD/DVD clening disk ($6 in Walmart). Or simply use cotton swab (Q-TIP) and 40 % ethyl alcohol (vodka) or 50-70% isopropyl alcohol (NO ACETONE), depending on your budget.
Also check if discs are inserted correctly and not damaged/durty etc. Also check your discs. Some CD-players dont accept burned CDs (copyed). I believe Sony is not the case, just a suggestion.
If cleaning wont help lens might be damaged.
Good Luck
Jan 26, 2009 | Sony CFD-Z501 Boombox
Sony PMC-R35L "no disc" message
That is usually because of dirty or defetive lens.
Try first using a len cleaner , like the ones here.
If this does not work it will be necessary to take apart the unit and accees the lens to clean it, or replace the lens pickup. The repair must be done by a technician.
In this case call the number listed on the owner manual to get assistance
Dec 16, 2008 | Sony CDP-CE275 5-Disc CD Changer
Sony CFD-S300 boombox would not run CDs
what i would suggest you to do is get a q-tip and a little bit of rubbing alcohol on the tip and gently clean the lens let it dry
May 22, 2007 | Sony CFD-S300 Radio/Cassette/CD Boombox
Sony CFD-ZW155 Cassette/CD Boombox Logo
186 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
