Question about Sony Televison & Video
My sony KP53V75 was playing then the next day turned it on sound and the LED is just flashing
  • 10,594 Answers
KP-53V75 is 1998 model tv.
Horizontal deflection section failure is common problem in these models and blinking standby light is sign of error that shows tv got some internal problem.
I'm not sure about your electronics knowledge level, however, unplug tv from AC socket and check horizontal output transistor on G Board in tv as it contains horizontal deflection section, check flyback transformer and/or high voltage block that could be one of reason of problem. Power supply section is also located on G board so follow AC cord of tv that goes to G board.
If you are not familiar with tv circuit board repair then local tv repair shop is an option to get tv fixed.
Let me know if you have additional question.
Thanks.
Posted on Aug 05, 2010
  • 2 more comments
  • John Ryan
    John Ryan Aug 05, 2010
    do you know the pin numbers on the G Board for the horizontal output transistor
  • Shahid Electronics
    Shahid Electronics Aug 05, 2010
    Yeah, get back to you with PCB image that will show you H-Out transistor location on G board.
  • John Ryan
    Thank You very much
    Check Q502 near Flyback transformer as shown in below PCB image.
    Q502 part number is as follows:
    872902405.... 2SD2348
Schematic for vizio vbs210ws
According to the user manual, the fourthj LED flashing (Error D) means that a thermal (heat) shutdown happened. If Error D, Thermal shutdown, is indicated, turn off the Sound Bar and verify the ventilation slots in the Sound Bar are clear, the Sound Bar has proper ventilation and is not being operated in an environment
that is too hot. If these conditions exist, reduce the volume level for the particular source content being played. My bar did this and I left it disconnected from the Ac power a full day , and it powered up the next day.
Aug 30, 2012 | Vizio VSB210WS Soundbar
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
Aug 04, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My ps3 was fine 1 day and then the next day i went to play on it it wouldnt work it sounds like the fan starts up and then dies what should i do???
does the lights to this
gren and blue on
yellow light on (one second)
red light flashing
if so you need to call sony you have broken the system
this can be down to several things
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
Sony mhc-GX450 mech error
unplug the system.take out any extra speakers,and try plugging it back in.
Feb 24, 2009 | Sony MHC-GX450 CD Shelf System
Kv-32s120 standby LED blinking no sound or picture
How many times does the timer light flash between pauses?
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
3 years ago, i had the same problem with a samsung 36", when i switched it on it would stay on for around half an hour, i tried to switch on straight away, but it wouldnt, i had to leave it for an hour or so, then it would stay on for about 5 minutes. And the same thing the next day (half an hour then 5 minutes). I left it into the repair shop, it had to get a circuit board replaced at a cost of £315, dont know how much it will cost to get fixed now, as i could buy the same tv for a little over that now.
Apr 14, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV will not turn on
check the items listed in the image to locate the 5 blink error. good luck.
Jan 03, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
