Question about Roper RAS8445KQ Top Load Washer
Washer just got my roper washer used. There is one problem the inside the washer it moves more than it should . Like if you were to use it might not stay in place . It rocks to much. I haven;t used it yet for that fear. It feel like it need to be pick up and place back it something that steady it. I hope you can please help. sarah
  • 135 Answers
There are only springs that balance the machine. An even amount of clothes inside the washer keeps it balanced. But on the ropers the tub is designed to be very loose like it is. Load the machine evenly and you should be fine.
Posted on Apr 26, 2008
I just moved into a new place and hooked up my Roper 111-07 washing machine. I have notice that no matter what temperature I select for the rinse cycle, hot water is the only thing that comes out. I only...
Hello Stephanie Wells,
Since it is the "new place" that changed...
I would FIRST look to the COLD WATER supply
to make sure cold water INDEED comes out of the
MACHINE END of the hose.
Then move on to the cold water valve...
>> Take PICTURES before disassembly.
Not terribly expensive... Pretty easy to change.
(you may get your NEW PART as differently
connected than your old (PRESS FIT couplings
are replacing the OLD threaded type...
ALERT: PRESS collar in to release tubing)
HELPFUL VIDEOS:
Check these (USA) parts suppliers to
find your specific water valve
(even available through AMAZON)...
Let price/reputation be your guide...
ALL these folks peddle the same parts (opinion)
appliancepartspros
Search Over 2 1 Million Appliance Parts
AMAZON: Roper
285805 Roper Washer Washing Machine Inlet Water Valve Replacement
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Good luck
Carnac the Magnificent
May 08, 2017 | Roper Washing Machines
Hello Everyone, I have a Roper Top Load Washer (Model # RAX7245JQO) Type 107 It has been working fine until yesterday. I noticed it stopped after it filled with water before the wash cycle and would...
that sounds like you have done all you can and i appriciate a well written question stating exactly what you have already done(some times questions here is "it dont work") so then back to your washer. There are 2 more possiblities
1) the motor capiciator is bad and not giving the motor a bump in power to start it. To check that,its black and round and going to be on inside right side of back panel.To check it use a meter set to HIGH ohms rating.place one meter lead on each of the 2 terminals (each terminal may have 2 wires but only 2 two terminals) and the needle should swing up and drop back if cap. is good and the needle will stay at or near zero if cap. bad. If using digital meter the numbers will constiantly be in motion jumping from 10 thousand to 200 back to 5 thou. and so forth if cap is good and again the display will stay the same and never change if capiciator is bad
If capiciator checks good the motor is going to be the problem
Good luck,i have i have been able to help you fix your washer,
Gene
Aug 18, 2011 | Roper RAS8445KQ Top Load Washer
How do I find the water pump on a roper? Need to find out why the water won't drain.
disconnect the power supply then shut your water off unscrew your water hoses,then move washer out of it's space and look at the back panel proceed to unscrew the back panel look for hose connection that is water pump. If you overload washer with too much weight it will not drain also if you use too much soap it will cause a roper not to DRAIN this has happened to me check your drain line make sure it's properly installed ,take drain hose off and make sure it is clear you may have something stuck inside
Sep 26, 2010 | Roper RAX4233PQ Top Load Washer
My roper washers top half of the agitator stoped
you will need a flat blade screwdriver long plyers 7/16 socket and ratchet, the verry top of the agitator prys off look verry close you will see a spot to put the screwdriver, then take the plyers and carfully reach in side and pull on handle of the domed shaped piece gently. then remove the 7/16/ nut. then lift off the corkscrew top portion of the agitator. you will see 4 tear drop shaped pieces called dogs part # 80040, look at the way there in there so they can be put back right later, use a camera take pictures as you go to each step for reasembly.the thrust washer will probly need replacing to, it's the plastic washer that the cork screw part sits on. when you go to put it back together use some vasaline where the dogs go in the holder, this will help hold them in place durring assembly. look close at holder for square holes they need to line up with the flat pins on top of lower portion of agitator. use an exstention and a large socket to hold dog holder in top in agitator top wile puting it on lower half. use the bag the dogs came it to hold the bolt in the socket til you get it started, then pull bag off before tightening. use two exstentions to put inner cover back in then put main cover on you are done,be pacient this may test your pacients.
Jan 08, 2010 | Roper Washing Machines
Starts, but does not move on through cycles
check your lid switch may be broken. or could be your timer does it stop and not advance? if it gets stuck you more than likey have a broken lid switch. but if it gets stuck in one cycle and keeps washing and washing and washing you more have a bad timer.
Jan 05, 2010 | Roper RAB2121KW Top Load Washer
No clips found! To remove top or front
Check out this diagram. Sure hope this helped and best wishes.
Jul 27, 2009 | Roper RAS8445KQ Top Load Washer
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
I have a Roper brand top loader washer and it fills up but it won't drain or spin.
If the motor doesnt run during the spin cycle and the tub stays full of water. You need to replace the lid switch. This is very common problem. The part should be around 35 bucks. Easy fix.
Jan 30, 2009 | Roper RAK2751WWH Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
117 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
