Question about Frigidaire Electric Dryer
Just delivered runs fine not heating up? - Frigidaire Electric Dryer
    Sergeant:
  • 216 Answers
I would contact the seller or store you purchased this from and have a replacement send out. This has been a common problem and is due to bad heating elements and faulty circuit boards.
Posted on Aug 05, 2010
Changed the rad in my 2004 grand caravan 3.3L and now have no heat. what to do?
You've probably got an airlock in the heater part of the cooling system.?Take the car out for a decent run somewhere & give it the chance to heat up properly. Make sure the heater is turned-on to deliver as much heat as you can get out of it. If it works, remember to top-up the radiator after it's cooled down.
If it turns out that you still can't get it to blow hot, you can let it cool down & then take the header tank cap off.
Run it around with the cap off for a bit & see if it starts to deliver any heat then.
It won't warm up properly without the tank cap on, but it might have the desired effect.
Remember to top-up the header tank if necessary & put the cap back on.
Best of luck
Mar 14, 2018 | Cars & Trucks
Goodman gph1348m41ac unit is blowing cool air in heat mode with mid 30s ambient outdoor temp. I turn it off then on and will usually blow warm air but this cycle is becoming more repetitive. any expert...
A heat pump on the optimal heating day (about 50 degrees ambient) will only deliver approximately 85 degree air as compared to 125 degree air from a fossil fueled furnace. The colder the outdoor air is the less heat there is available to be transferred to the living space. At 30 degrees, the heat transfer capability is getting close to negligible meaning the run cycles will be approaching continuous and eventually as the heat pump along cannot maintain setpoint, the outdoor stat or stats will bring on auxilliary heat in the air handler.
If your ambient temp is below the 'balance point' of the heat pump, the house temp will drop a little lower and most times energize the heat strips through the outdoor t-stat. Your outdoor stat could be set too low for the heat pump to carry the structure all the way down to the balance point so when you turn it off and back on, the lower indoor temp automatically brings on the heat pump plus a heat strip or two, thus the warmer air. Second stage on the stat satisfies due to the heat strip, drops them out of the circuit and the heat pump is left running on first stage heat delivering the perceived cold air.
Your outdoor stat could also be not functioning correctly and not allowing the heaters to come on until the system is turned back on reestablishing the two stage call for heat.
Tons of possibilities and not enough room to list....
Jan 01, 2015 | Goodman Manufacturing Goodman GPH1348M41 4...
Why won't my acer Aspire turn on?
If it is not a defective ac adapter then "the jack is loose or bad" and it is not making a good contact for the adapter to deliver power.
If your are brave you can also disassemble the laptop, clean the fan and the end of the heat sink. Clean CPU and heat sink and apply one drop of thermal compound.
It could be a greater problem so consult with a tech person.
Apr 23, 2014 | Acer Aspire Computers & Internet
I have a 1994 Chevy Suburban, the heater doesn't work, yet the air conditioner does.
The heater uses water to deliver heat and the A/C delivers cold with freon. If you have no water, the heater valve is stuck, or your heater core is plugged, you will not get heating but your A/C will still work just fine.
Nov 10, 2010 | 1994 Chevrolet Suburban
Hello, I have a rbha-17 electric heat system. My
the orange or blue wire should go to the heat pump and energize the reversing valve and the compressor should be running when the heat pump is on. All it does is reverse the flow of refrigerant and pull btu's from the outside air and deliver them to your house. Check to see if your aux. heat is coming on with the heat pump. If it is electric furnace, this will help explain why your bill is so high.
Jan 13, 2010 | Ruud UAMB042 Air Conditioner
1995 Polaris 300 4x4 runs good and dies after about 10 minutes of ride time, let it sit for a few minutes and starts up again ...repeat over and over again
sounds like a cracked coil winding. Typically a cracked coil will deliver a spark when "cool" but as it heats and the windings expand the gap in a cracked coil will increase until it's wide enough to disrupt voltage transfer. let it cool and it will work fine until it heats up again.
Oct 30, 2009 | Polaris ATV
New Whirlpool Duet gas dryer (wgd9300vu) won't heat.
if its brand new,
anmd its gas, well then more than likely it was dropped, when it was dropped the graphite ignitor craked or broke due to shock impact,
i delivered units for 5 years and saw this numerous times.
I would tell you to fix it your self, but its brand new, if the company you bought it from has service they should give you a free service call and part
Oct 21, 2009 | Dryers
Car fails to start one day and starts the next.
I would check all the relays and the computer .
They could be over heating when coming on for a while then shorting out.
Apr 01, 2009 | 1998 Chevrolet Camaro
Dryer will not heat and will not turn off at the end of the cycle
I had the same problem with my whirlpool LER5636. It was a power problem. My circuit breaker was fried (one side delivered 120v the other 26v). The dryer itself was fine. Check the breaker, the dryer outlet, and the connections where the dryer cord enters the dryer.
I replaced the breaker and all was well.
Good Luck.
Dec 27, 2008 | Whirlpool LER5636P Electric Dryer
Frigidaire  Electric Dryer Logo
61 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
