Question about Tools & Hardware - Others
I have two rupes sanders, one is approx 15 years old ,the other approx 5 years old,both are stopping while working or sometimes wont turn on,if I tap the sander with a hammer then they start to work or sometimes not at all
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
It can be ascertained, there is a problem in the switch or the motor carbon brush, carbon has been eroded by the rotor rotation. you have to check and replace the carbon or switch.
Posted on Aug 05, 2010
Ridgid random orbit sander will not turn on
Mine also, in the middle of a job and it just stopped, no warning , did not slow down or bog just quit.
Apr 26, 2014 | Ridgid R2601 5-Inch Random Orbit Sander
Goes on works about 10 minutes. stop.try to turn
Problem is the motor is going bad. Sometimes the motor can almost cost as much as a new dryer. An excellent little dryer that will last and work ghood for you is Roper, made by whirlpool. Any Lowes store has these. Hope this helps.
Mar 19, 2010 | Frigidaire Dryers
Dripping showerhead mirasport 8.5 kw - shower is approx 15 yr old when switched to off continues to dribble then drip for hours after
It is normal for instantaneous electric showers to drip after shutting down. However, yours sounds as if the water stop valve is failing.
You could have this replaced ( or even cleaned out, sometimes they can be affected by calcium build-up on the seal) but realistically it's probably best to consider unit replacement....15 years is an excellent service span for an instantaneous electric shower.
Hope this helps.
Mar 03, 2010 | Home
I have a type 2,#92 heavy duty sander,length of right angle sander is 14".. approx 35 years old............need brushes. whee can I find these please...
First try Black & Decker Serves Department. At some Hardware stores (ACE, True Value, etc)they stock brushes in the back room.
Jun 12, 2009 | Black & Decker 4.3A 6" Heavy Duty Right...
Ryobi half-sheet orbital started screeching - any way to lube it?
Take that sander apart and you can oil the roller externally with a good lubricant not a gel like substance but oil that is made for things to move better. Doesnt have to be heat resistant after you have oiled both sides with the belt off. Then turn it on and let it mix. You may have to do it a few times to get it to work well again
Apr 26, 2009 | Tools & Hardware - Others
Hand sander stops spinning once placed on item to be sanded
This sander has a brake pad that is supposed to stop the rotation when the sander is not actually in use. It sounds like it's malfunctioning.
The only other thing I can think could be a cause of what you describe is an improperly assembled sanding base. Have you changed out the base, and if so, were you sure to properly align the replaced base on the machine before you tightened the allen screw?
If you're not comfortable disassembling a tool that is still under warranty ( I think it's two years for that one), I would recommend finding a Dewalt service center and taking it in for a factory service call.
Mar 24, 2009 | Black & Decker Black And Decker Cyclone 4...
Tools & Hardware - Others Logo
114 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
