Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
When I insert batteries in the camera it behaves strangely: the lens keeps going out and back in a couple of times before switching off.
    Novelist:
  • 82 Answers
This is a clear lens faulty. this f depends of a involontary prssure on the lens bl..or dop on the camera. , or camera is fall .
its probably that you must change the lens. you can fid the lens on ebay international seller. one entire lens cost from 25 to 40 euro.
you can find many videos on you tube. with lens changement explain. write this on you tube.
obiektiv umtausch so you can see if you are able to make this job alone. sorry for my bad english
Posted on Aug 05, 2010
How to fix a Fujifilm FinePix S4000
some times small particles or grit get into the lens housing and prevent movement... try holding the camera vertical with the lens pointing down and tap the back of the camera firmly a couple of times... keep the camera in this postion and switch the camera ON and OFF a couple of times to try and loosen any foreign particles... you may have to repeat this procedure several more times before you achieve success...
Apr 04, 2016 | FUJIFILM FinePix S4000 / S4050 Digital...
Lens Cover not fully open
It sounds like a problem with the firmware in the camcorder itself. As an authorized Sony repair person, I have gotten no technical bulletin on this model. The firmware is preloaded into the microprocessor IC. You will need to have this unit looked at by an authorized Sony repair center who specializes in camcorder repairs or send the unit to a Sony factory service center. good Luck
May 22, 2007 | Sony Handycam HDR-HC1E HDV Digital...
Tip
DIGITAL CAMERA MAINTENANCE
charge battery after every use
always remove battery when not in use
be smooth while inserting and removing usb cables
keep clean the camera case (leather cover / cloth cover)
never keep digital camera in your pant pocket (back pocket)
gently clean barrel unit (lens assy) before switch off digital camera
on Feb 06, 2010 | Cameras
Will not switch on with new batteries
I wonder what batteries you use? The best would be two AA rechargeable NiMH batteries. But a new CR-V3 lithium battery should work also.
When you have rechargeable batteries, you should check if they are charged. And when inserting, check if you did out them in correct. Only the CR-V3 is protected for inserting it wrong. when you have two batteries, you can put them in the wrong way. Then, if you did not use the camera for a long time, please make sure all contacts in the battery compartment are clean and shiny. If not, try to clean them, with a clean cloth. Never use anything sharp in or close to a camera. Contacts, could be rubbed with a little electronic contact oil, but the oil must be removed afterwards. As strange as it may sound, even the contact oil can be cause of oxidation on contacts.
When the batteries are in, make sure the battery door is correctly closed.
If you checked everything and you are sure the batteries are in correct, just try switching on and of several times, by opening and closing the lens barrier. Also while the lens barrios is closed, press the play back button on the back side of the camera. If both don't work, then again the batteries are under suspicion.
Feb 14, 2014 | Olympus Camedia C-150 Digital Camera
Turn camera on, lens comes out, goes back in ,and says lens error.
try these fixes
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable nimh 2500mah or better) and turn the camera on. If using rechargeables, and they're more than a year old, consider purchasing new rechargeable batteries as they may not be providing sufficient power to startup the camera. If new batteries didn't work, try pressing and holding the 'Function' or OK button while turning the camera on.
2.If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
3.Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
4.Insert the cameras audio/video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fix 3 as a means to provide extra power to help to this fix. Reinsert the cable only after tapping the camera.
Feb 07, 2011 | Nikon Coolpix S3000 Digital Camera
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
I have a Nikon Coolpix L3. A couple of days ago, I noticed that My camera was on, And the lens was out. I tried turning the camera off, but the lens wont go back in. I tried Wiggling the lens, Tried...
a lot of camera seem to be having this problem. keep trying to turn counter clock wise. but do not force it keep wigging back and forth it will go it just gear driving. and problem got hun up do this with the camera onand then try it with it off
Mar 05, 2009 | Nikon COOLPIX L3 Digital Camera
L 100 digital camera is not switching on though the battery is fully charged.
Try removing the battery for a couple of seconds then insert it again. Click on the power button, it should turn on and turn it off again to close the lens.
Oct 17, 2008 | Samsung L200 Digital Camera
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
Camera won't stay on; date/time won't stay set
Are you sure the lens is actually going all the way out? If there is debris in the zoom gearing it can cause the lens to stop extending which would in turn cause the camera to re-retract the lens and show an error. Other possible explanations are that the sensor which determines when the lens has reached full extension has failed, so the camera keeps extending the lens until it reaches the physical limit - and then behaves just as if there was a jam as described above. The fact that this occurs both when you power on and power off the camera leads me to think this may be the case. The loss of date and time settings is due to a dead backup battery. Check your manual to see if this is replaceable by you or if it requires disassembly. David Millier Advance Camera Repair
Feb 17, 2007 | Nikon Coolpix 4300 Digital Camera
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
