Question about HP G60-120US Laptop
I need to replace the screen on my friends HP G60-120US and i'm looking for some step by step instructions as this one is a bit different from the last laptop i worked on. Any help would be appreciated.
tparsenault
  • 170 Answers
SOURCE: Replacing the screen on an HP DV2040TX notebook computer
http://www.lcds4less.com/laptop-lcd-removal-instructions.shtml
Posted on Jan 01, 2009
micromend
  • 748 Answers
SOURCE: Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Posted on Mar 23, 2009
ghassun
  • 499 Answers
SOURCE: space bar missing on hp dv9000 laptop
hi go to this site and absolutely u will be able to change ur keyboard with new one http://www.insidemylaptop.com/remove-hard-drive-memory-wireless-card-keyboard-hp-pavilion-dv9000/
Posted on Jun 06, 2009
  • 14 Answers
SOURCE: how can I install Winxp on HP pavilion DV5 laptop ?
You're Hard Drive may be dead. If XP is starting to install and then it goes to the Blue Screen of Death, that's most likely your problem. There's a slight chance that you're power inverter has a fluctuating power level that is causing a disruption, but that's very unlikely. Have you done any tests with any boot CD's to check the hard drive's function?
Posted on Jun 09, 2009
benwabnick
  • 2404 Answers
SOURCE: Replacing lcd screen on HP dv4-1120us laptop
Here is one place I found thru google that sells your lcd for your laptop:
http://base.google.com/base/a/1453857/D14569028068669548660
Price is about $89.00 before any S/H charges. I'm sure if you do some research you may find them cheaper.
When it comes to replacing the lcd on these laptops most of the time its done the same way. Unscrew the screws on the front lcd bezel and then remove the bezel so it will expose the lcd with a hinge on each side.
Remove the screws on the left hinge and also remove the screws on the right hinge.
At this point the screen will be loose. Disconnect the power connector from the bottom of the lcd that goes to the little rectangular inverter board.
There will also be a cable on the back of the lcd screen that needs to come out as well. Be gentle with the cable cause its sensitive.
At this point you can remove the bad lcd and then get ready to put the new lcd into place.
Go ahead and connect the lcd cable to the back of the lcd, don't worry it is slotted so it can only go in one way and it will kind of snap into place. Then go ahead and align the screen with the left and right hinges so you can put the screws back on so it keeps the screen in place.
Then go ahead and connect the power connector to the rectangular inverter as well. Now that you have the screen hooked up. Turn on the laptop and if you get video then you know the screen is good, turn the laptop back off and then go ahead and put the lcd front bezel back on and put the screws back into place and you should be good to go. I know this was lengthy but hope this information helps.
Posted on Jun 18, 2009
Plz help
And THIS is a PROBLEM?
OH, I'M JUST KIDDING!
LCD screen needs to be replaced. It's so easy to do, you will be amazed. (...............OK, maybe a little enlightened)
The only "go G62' laptop that I am aware of, is the HP G62 series of Notebook PC's......Don't know about the 'go' thing.
Need the model number off of the bottom of the laptop.
(If an HP, look in the white Service Tag on the bottom of the laptop.
Need the Product Number. P/N = Product Number)
Post back in a Comment.
This way I can step by step guide you, and also post a few examples of LCD screen replacements. This way you will get a feel of how to look for a replacement LCD screen by yourself.
(You may be better at it, it may differ for the country you are in {Accessibility}, and it won't look as though I may be advertising for an LCD screen replacement store.........I DON'T, lol!)
Let's say it's an HP G62 series of Notebook PC,
https://www.laptopscreen.com/english/model/hp-compaq/hp%20g62-244ca/
http://www.laptopscreenonline.com/hp-g62-100-laptop-replacement-screen-18955-p.asp
Regards,
joecoolvette
Apr 27, 2013 | Computers & Internet
Need step by step instruction for screen replacement of hp pavillion laptop
It would be hard if I type it here. It's better that you can see it.
There are a lot of tutorials in Youtube. I'm pretty sure that you can find one from there.
David
Mar 18, 2013 | HP Pavilion dv1000 Notebook
I need to download the the driver for hp380 for this computer to solve the problem
you can download it from the hp website. but before you click on the links below,first determine the flatform or system type of your operating system.you will be needing that in downloading the correct software.here's how to do it: -click on start (pearl button) -right-click on computer or my computer -go down to properties -look for the operating system and system type (32-bit or 64-bit)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=1128296
step 1: select your operating system step 2: hit next step 3: click on driver and click on HP Deskjet and Officejet Full Feature Software and Drivers or HP Photosmart Software and Drivers: USB Support note:if you want to use the scanning feature,always download the full feature software and driver step 4. Click the Download only button. step 5. When prompted, choose Open to start the download and run the software installer. step 6. Follow the on-screen instructions to start the installation process. step 7. Connect the USB cable between your HP all-in-one device and your PC when directed by on-screen instructions, and turn on your HP all-in-one device. step 8. Wait for additional on-screen installation instructions before using the all-in-one.
Jun 06, 2011 | HP DeskJet F380 All-In-One Printer
Do not have program for hp officjet 4300 all in one series i want to install the program in order to use printer to scan, fax, copier
now let's go on to the download page.check out the links below:
HP Officejet 4215 All-in-One Printer http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351106&lc=en&cc=us&dlc=en&lang=en&cc=us
HP Officejet 4315 All-in-One Printer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1138342&
step 1: select your operating system step 2: hit next step 3: click on driver and click on HP Officejet and PSC Full Feature Software and Driver or HP Photosmart Full Feature Software and Drivers note:if you want to use the scanning feature,always download the full feature software and driver step 4. Click the Download only button. step 5. When prompted, choose Open to start the download and run the software installer. step 6. Follow the on-screen instructions to start the installation process. step 7. Connect the USB cable between your HP all-in-one device and your PC when directed by on-screen instructions, and turn on your HP all-in-one device. step 8. Wait for additional on-screen installation instructions before using the all-in-one.
Jun 06, 2011 | HP Officejet 4215 All-in-One Color Photo...
Need instructions for replacing ADF lid on\ HP L7680 copier.
Replacing it is a bit difficult, however here are the steps and link that can help you:
Through this link it will give you step by step instruction with pictures http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
I hope this can help you resolve the issue.
Note: Make sure that you have acrobat reader install yto your computer.
Thank you for choosing Fixya
Feb 28, 2011 | HP Officejet Pro L7680 All-In-One Printer
Dear Sir I am looking for a step by step instruction booklet for the use of fred carbide router bits door system model 94-100 Paul
The bit set you're   is for the purpose of making cabinet doors, cabinet pulls and door pulls.  It's a great little system from a good company. Unfortunately, it's intended to be used by people who have routed before.  I don't know what your experience level is  this stuff but you have several different types of bits there.  You're not going to find step by step instruction on this kit, but what you can find is instructions for the different "type" of bits.  For example, the kit includes a 99-510, which is a raided panel bit.  Do a search for that.  Freud won't give a step by step on that kit, but the styles (not stiles) they offer are universal.  Also, here's 2 good resources.  A picture's worth a thousand words and I think some of the illustrations will help.  Remember, test your cuts on scrap stock, don't waste the good material.  Happy routing  http://www.newwoodworker.com/bldraspnldors.html
http://www.binkyswoodworking.com/RaisedPanelDoor.html
Apr 09, 2009 | Tools & Hardware - Others
Jan 01, 2009 | HP Pavilion dv2000t Notebook
I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
[This is from HP.com]
Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
Insert the print cartridges
NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Open the cover c00393707.gif
  3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Original Page here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
Regards,
Worldvet
Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
Hp pavilion dv 1000 screen replacment
Dear lotaman, I have searched the world to find an exact guide for your monitor but it is impossible. Neveretheless I have found the following guides and they should be more than enough to complete the task in hand anytime.
TIP: The ZV5000 looks and is very similar to the HP DV1000 screen so I would start from there. All guides are very nicely explained.
Please remember to remove the battery before you do any work with the laptop.
Regards
Removal Step by Step HP ZV 5000 LCD Screen
http://www.instructables.com/id/SJFP10QF49G0AOR/
Removal Step by Step Compaq V2000 LCD Screen
http://www.screentekinc.com/lcd-removal-instructions_en,compaq.shtml
Removal Step by Step Compaq DELL LCD Screen
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Mar 25, 2008 | HP Pavilion dv1000 Notebook
HP G60-120US Laptop Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
