Question about Aiwa CDC-X504MP CD Player
The automatic CD feeder isn't working and so CDs can't be played. The CD isn't "grabbed" by the slot and fed into the player - inserting a CD too far leads to a stuck CD (not a problem now). All of the other system features are working, including display, volume and radio.
  • 15,935 Answers
This is an internal problem that will need servicing/parts.
You may find the repair bill, however, to be more than the cost of a new unit.
It is likely a servo motor or internal limit sensor has failed on the cd carrige.
Thanks!!
Posted on Aug 05, 2010
I am getting an error read on my CD player. The CD Disc CD player (original) to my 2003 Experdition will not release CDs. The CD player which is an automatic feed was force fed a CD by a minor child. The...
The unit can be removed but disassembly will be required to remove the OFFENDING CD. Even at that, the player mechanism may have been damaged so that CDs simply cannot be played at all
Jan 28, 2013 | OEM 2002-2004 Ford Focus Factory AM/FM...
2011corolla s cd player...
Isn't this till under warranty?
May 04, 2012 | Cars & Trucks
I got an Sony HCD S 300 Home Theater set recently. As I put in dvds and cds for playing, the dvd player says NO DISK. Thinking it is because it is not a original dvd it isn't working, I put another DVD...
It could be down to the Region of the Player or the Laser is Failing. As it doesn't play CDs then I suspect the the Laser is Failing (almost failed if it plays a cleaner but not CDs).
May 05, 2011 | Sony DAV-S300 System
My jvc player rejects my cds when I put them in. what do I do?
The mechanism that controls opening and closing of the tray is bad, that is why it keeps ejecting cds when inserted in.
Unplug the player and unscrew it open then plug it after opening the cover and try to insert a disc and see the how far the cd goes before ejecting, be sure not to touch any metal part in the player to avoid shock.
After trying to play a cd, you will notice where the tray ejects the cds from, it is located try to unplug the player and disassemble the mechanism, you will see either a worn out rubber or teeth on the mechanism, then replace them and reassemble it back together, after doing that, the player will be able to hold a cd.
Take care and good luck
Dec 02, 2010 | JVC KD-S640 CD Player
CD Player in caravan doesn't play burned cds.
the CD player is a clever one thats looking for the copyright on the CD .Try using nero to burn the cd that oftens fools the player ,or an old computer with windows 98 on it with a copy of the old nero or windows media player that come with windows 98 as the later versions will not work with a lot of expensive players .if it has a line in plug then use a i pod or your mobile phone ,if it has a tape player then use a cassete with the wire coming out that plugs into a audio device ,i use my mobile phone which has a 1gb memory card in my jag as i have the same problem with the cd player ,also in the every day car my escort i use this as iam fed up with having the window broke and cd player nicked .But i have found that burning cds with an old computer with windows 98 i can burn cds that will play in the jag ,not that i use it a lot cant affords the petrol here in spain at 5 dollars a gallon
Aug 01, 2010 | 1999 Dodge Caravan
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
Just stopped playing CDs
Hi in most cases the mod kit will fix the problem. other wise its a new unit as Blaupunkt only supply the mod kit or a new mech...
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html?osCsid=b7ce3a0b7b492ec864e29579ad046166
Regards
Mark
Nov 26, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Aiwa CDC-X504MP CD Player Logo
Top Aiwa Car Audio & Video Experts
fordexpert
Andrew Taylor
Andrew Taylor
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
