Question about Acer Aspire L100 PC Desktop
My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
  • 146 Answers
You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
Posted on Aug 06, 2010
Asrock N7AD-SLI Motherboard LED
The fans and indicators working for a sec would normally mean that your power supply is Ok. This flash of current must trigger a switch in the mobo to start the boot process. This is not happening. The RAM is a principal player here if it does not connect the memory to the processor nothing will happen. Assuming the RAM is correct and has worked faultlessly before, remove and clean the teeth with an eraser. This prob can also be caused by the VGA card not connecting. Usually alarms sound if your mobo speaker is connected but that depends on each mobo. These are basic steps that usually start machines that have been inactive for a time or have recently been exposed to high humidity. There could be other faults...............
Aug 28, 2012 | Asrock N7AD-SLI (4711140872940)...
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I have a problem with starting up windows. More often than not when I press the power button I can hear the fan going, the power light is on, but it won't go any further to start up Windows. Sometimes it...
    Had something similar to your problem ... power on but no system boot ...
    Change the CMOS battery on the motherboard - it worked for me maybe for you :)
    Jan 22, 2011 | Acer Aspire L100 PC Desktop
    My Acer Aspire L100 PC Desktop won't start.. when i press power button it only flash LED light jus one time but no HDD sound or CDROM working sound. only CPU fan works thas bout it...Any help? pls
    Do you see anything on the screen?
    Try the following things:
    1. Try starting the computer with only the battery
    2. Remove the battery and try booting with only the power adapter
    3. Try removing and replacing your memory
    Could be a bad power supply or bad battery. After you try the above steps, report your results.
    May 22, 2010 | Acer Aspire L100 PC Desktop
    ACER Aspire L100 Desktop is dead?
    If the hard drive is OK then you can remove the hard drive from the desktop case, and insert the hard drive into a USB 3 1/2" hard drive adapter case, this should come with a power adapter. These are available at your friendly computer shop.
    Boot up the laptop then plug this USB hard drive adapter into the laptop's USB port. The laptop will see this as an external USB hard drive. You can open the various folders and files on this external drive and copy the folders and files to the laptop.
    You can delete the Windows folder and Program Folders on this external drive to free up disk space and use this as a back up drive etc.
    If you are not sure how to remove the hard drive and install it into an USB hard disk case, then I suggest you get a computer savy friend to help you.
    Dec 08, 2009 | Acer Aspire L100 PC Desktop
    Won't come on. when I push power button the blue
    Check id main board is getting power of not , You need to open tower and check if processor fan is stuck , Open RAM module and clean the slots , Check all power cables , Before unplugging th power cables make sure there is no electricity pass on tower , post reply for any clarification
    Sep 07, 2009 | Acer Aspire L100 PC Desktop
    Start up trouble
    when you press ON button try to press the eject button of the cd-rom drive. last night we have the same problem.
    Apr 09, 2008 | HP Compaq nx5000 Notebook
    Acer Aspire L100 PC Desktop Logo
    206 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
