Question about Efficient Networks SpeedStream 5100 Modem
Cant get speedstream modem into bridge mode so that I can set up airport extreme to apple laptop
  • 4,889 Answers
Hi I was in a live session with you earlier. Seems like you lost contact after restarting your router. Any luck?
Posted on Aug 05, 2010
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
I've connected my airport extreme by ethernet to my modemrouter Thomson TG585 V7 in bridge mode, as soon as i connect a speedtest on either machine drops by half, disconnect the airport and the tomson...
Simply put, a bridge evenly splits bandwidth, a monitor will, to measure, run upload/download tests by transmitting data which is EXACTLY THE SAME as downloading or uploading data to any other server. Brain engage.
Aug 04, 2010 | Apple Computers & Internet
Can you help with apple airport extreme networking?
What kind of help do you need? That's a big topic! Describe to us your environment that you have . . . who is your broadband provider? What kind of Macs do you have? I have ATT uverse. I disabled their wireless ( slow ) and then added my Airport Extreme in bridged mode on the WAN side. On the LAN side, I chose an SSID, and 'created a network', and set the protocol to B/G with WPA/Personal authentication. It seems to work just fine . . .hope that helps!
May 21, 2010 | Apple AirPort Extreme (AIRPORTEXTREME)...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
I want ot disable DHCP on apple extreme router. Because MS 2008 SBS R2 scans for DHCP servers and fails to config if found an other dhcp server (apple extreme)
1) Open Airport Utility (Applications/Utilities).
2) Select the Airport Extreme in the left hand panel and press Manual Setup
3) Choose Internet in the top menu bar
4) Change Connection Sharing to 'Off' (Bridge Mode.
Press update to restart the Airport and save the settings.
Mar 16, 2009 | Apple AirPort Extreme Router
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Speedstream 4200
I keep get a NAT type 3 on my ps3. I've been told when plugging the modem straight into the ps3 it should be type 2. After looking on the net it seems that there is some type of problem because of the Speedstream 4200 Modem. Is there some type of setting I could change on this modem to make it better?
Sep 04, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
Aug 27, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Efficient Networks SpeedStream 5100 Modem Logo
216 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
