Canon PowerShot SD550 / IXUS 750 Digital Camera Logo
Posted on Aug 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cable ribbon for backlight is damaged. where to get a replacement? Canon Ixus 750.
Anonymous
Level 2:
Novelist:
  • Expert 82 Answers
  • Posted on Aug 05, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
82
Questions
0
Helped
12844
Points
240
Go on ebay international seller..its possible to can find replace for your model..or search a faulty camera on ebay international..and pull out the replacement from the falty camera. paolo sorry for my english
  • martin_is199 Aug 05, 2010
    Wow fasssst reply..thank you. I have looked on ebay and searching for replacement/faulty camera but wanted to see if there were any actual replacements for the backlight available standalone. Thank you.
Love my camera! I dropped my Canon SD550 for the umpteenth time and now the LCD screen is black. I can take pictures through the view finder and view them on my computer and the pictures are still great,...
It might be just a dislodged backlight ribbon cable. See this link, paying particular attention to Step 8. If you know of someone with a little electrical background, ask them to make sure that the skinny backlight ribbon cable is properly seated within its connector.
Canon Powershot SD750 powers up fine; lens extends fine. The LCD is black. I can see a faint image - enough to enter the menu and change settings. Increasing brightness has no effect. Seems like the screen...
It's not the screen, but its backlight that is the problem. It's likely a poor connection of the ribbon cable in its connector socket. This problem will require either professional repair, or your opening the case to reseat the backlight ribbon cable in its connector. Here's a disassembly of a somewhat similar SD600 to give you an idea of what's involved.
Canon digital ixus 750... problems with flash
Your flash or mainboard are bad, only way to know which is to replace one and see if it starts working.
If you can't find a suitable parts donor camera online please let us know, we can get boards for only about $45.
Thomas D
Owner; Darntoothysam com
I was replacing my screen on the SD800IS.
Sounds like you need to also reseat the skinny ribbon cable. Believe this is the one that provides power to the backlight:
http://blog.jharding.org/2008/05/replacing-lcd-on-canon-sd850-is-few.html
1helpful
Looking for a free manual for a canon ixus 750 for free download
The model # helps, you posted this under sd 550 and put ixus 750,
canon does not show a ixus 750.
This is there website, look around for your model.
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Ixus 750 advanced user guide!
Here is the advanced user guide: Camera User Guide Advanced
I will be grateful if you can take time to rate solution appropriately.
Many thanks.
Canon ixus i7. LCD screen is cracked, and thus does not sdisplay any image, however the camera still zooms, takes pictures, etc Obviously now viewfinder so only way to see what your taking pic of is...
I know some canon LCDs can be replaced by the user. Canon will sell you the specific part or you can find them on ebay. The LCD ribbon cable can be easily pulled out and with a little fiddling a new one can be put in. I have not personally done it with at ixus i7. When I did it it cost like $45. Goodluck!
here are some photos of the process for a canon SD. I know the i7 might be a little different.
canon lcd replacement images.
Jul 12, 2008 • Cameras
2helpful
5answers
SD400 broken screen
found this guide on the net once, try it out and let us know what you think: " WARNING: this repair voids your warranty and may damage your camera. Perform at your own risk. The publisher of this site is not responsible for any damage you cause. This replacement is of medium difficulty. If you have ever ?built? a computer from parts, you are probably capable of it. If you are patient, orderly, and meticulous, you can probably do it. But you do risk breaking your camera even further, so don?t do it if you won?t accept that risk! Be carefully that you are grounded and thus do not harm the camera via static discharge. Google the terms ?grounding? and ?static discharge? if you need more info. I only performed this operation on a Canon SD300 / Ixus 40, but readers have reported that it is the same on the SD200 / Ixus 30 and on the SD400 / Ixus 50. Read all of the instructions before proceeding. Within each step, I don?t necessarily use exact chronological order. Tools: a small Phillips head screwdriver and a smaller flathead screwdriver (used for prying). Step 1. Ascertain what is broken. Symptom: your screen still glows with light, but shows crazy colors or a visible crack surrounded by crazy colors. Problem: your LCD screen is broken but your backlight still works. You need only purchase a new LCD screen. Symptom: your LCD does not glow. Problem: your backlight is probably broken. This didn?t happen to me, so I don?t give any further advice about this problem on this page. However, the information on this page will take you about 60% of the way to replacing the backlight as well, so it may be useful. Step 2. Order a replacement screen. UK: H. Lehmann's Ltd: +44 (0)1782 413 611 at a cost of 33 GBP (including shipping) US: Canon? +1 732 521 7230 / +1 800-828-4040 at a cost of around 66$ (including shipping) The part number for the SD-300 / Ixus 40 LCD screen (without backlight) is: ck9-1103 The part number is the same in the US & UK. I do not know whether the SD-200 / Ixus 30 LCD / SD-400 / Ixus 50 LCD part number is the same.. Step 3. Open the camera - Remove 6 screws in total: 2 from the left side, 2 from the right side, and 2 from the bottom. - Gently pry open the case - The plate covering the ?grommet? to which you attach the strap will fall off. So will the round grommet. Don?t worry about it. Step 4. Remove the screen & backlight assembly from the back of the camera - Remove the screw from the upper right corner of the backlight/LCD package. Note: this screw is of different size to those you have already removed. Keep it separate. - Be careful of the tongue extending from the bottom right corner of the backlight/LCD package. It?s very tiny and easy to miss. You want to be sure to slide it out, because it?s easy to just break the plastic into which the tongue slides. (I did. Not a huge crisis, but I wish I hadn?t!) - There is a tab on the left side of the backlight/LCD package. Pull it back slightly so you can lift the backlight/LCD package. (I used the flathead screwdriver to pry it off.) - You should now be able to lift up the backlight/LCD package. It will still be connected to the camera body via two ribbon cables. Step 5. Separate the LCD from the backlight - There are a number of fiddly plastic/metal tabs holding the two together. Just gently pry and poke until you have separated them. It?s a bit time consuming, but I can?t really give better instructions than these. - You should be left with the LCD totally separate from the backlight, but still connected to the camera via a ribbon cable. - The backlight should also remain connected to the camera via a ribbon cable. Step 6. Undo the LCD ribbon cable - The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket. - Examine carefully the way the ribbon cable is attached to the socket. Note that it is pushed in entirely, so that the wider part of the cable (with two holes at either side of it) is flush against the socket. - GENTLY lift the clasp (I used the flathead screwdriver). It should swivel up and the ribbon cable should fall out. DO NOT YET PULL THE RIBBON OUT OF THE CAMERA. Step 7. Totally remove the LCD - Tape a long, narrow strip of paper to the end of the ribbon cable. This paper is to help you thread the ribbon cable of the new LCD back through the inside of the camera. - Note how the ribbon cable is threaded under the tripod mount to the front of the camera. Wiggle it around a bit, get a feel for it. Sliding the new one back through is a bit tough, so experiment with how this one fits and where it goes. - Gently pull the ribbon cable out from under the tripod mount, leaving the broken LCD screen now completely detached from the camera. Make sure to leave the paper threaded through the camera so that you can tape it to the new LCD?s ribbon cable and pull that one back through. - If you messed up with the paper, don?t worry. You can still push the new ribbon cable through: it just takes some wriggling and some time! Finishing. - You have now got to go through the process in reverse, installing the new LCD screen. - Threading the LCD ribbon cable back under the tripod mounting screw is tough. Just keep sliding it back and forth and exert pressure to push it through. It will go through, eventually. - As you connect the LCD ribbon cable, read the ?white screen? problem below, so that you do not suffer from it! FAQ 1. My screen just shows white or gray. (E.g. white screen, white display). What did I do wrong? A. The ribbon cable that connects the LCD to the circuit board was not inserted deeply enough. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the "socket" deeply enough that the wider portion is pressed right up against the "socket." Physically, it cannot be inserted more deeply. It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket." If you feel like supporting the author of this thread, go to his website through this link: http://www.cl.cam.ac.uk/~jo262/broken_lcd_cracked_screen_canon_sd-300_sd-200_ixus-40_ixus-30.html Good luck
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
