HP Officejet 6310
Paper jam shows but NO Paper at all in feeds or in printer.
Thanks
J
    Genius:
  • 3,587 Answers
Hmmm...well...that could be from a variety of issues..
Posted on Apr 26, 2008
Hp officejet 6310 carriage jam
it require servicing if you can apply the any lubricant on the steel rod inside the printer it will fix your problem if it is not then i advice you to show it to service center.
Nov 13, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All in One - small paper being faxed is jammed. How do I unjam the paper?
Lift the scanner lid, then lift the black part of the fax - pull up hard for it to lift. Unjam the paper either still on top or gently lift the inner section and retrieve your jammed paper. Then put everything back together and you're right to go again.
Oct 08, 2009 | HP Officejet 6310 All-In-One InkJet...
I have an HP officejet 6310xi that is not feeding the paper through. I can't print or copy anything. I have gone to the HP.com site to try their troubleshooting methods, but nothing is working. I have a...
Not sure if you're saying it's jamming or it's not picking up paper.
If the paper is jamming, this video should help.
If the paper won't pick up, this video should help.
Sep 25, 2009 | HP Officejet 6310 All-In-One InkJet...
HP 6310 - paper misfeeds and bunches up to one side when feeding into printer, causing paperjam. I tried cleaning the rollers, with poor results. Thanks for any help.
Please try these steps
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp 6310 officjet all in one paper jam error
This video won't help if it's really broken, but shows you what to do for a recurring jam on the 6310.
Apr 01, 2009 | HP Officejet 6310 All-In-One InkJet...
Continual Paper jam HP Officejet 6310
There's a couple things that can cause recurring paper jams. Most often, all the pieces of the jammed paper aren't removed. This video shows you where to look to find all the jammed paper. It also offers some other solutions as well. If the solutions in this video don't work, the printer is likely broken.
Jul 07, 2008 | HP Officejet 6310 All-In-One InkJet...
HP OJ 6310 All in One Paper Jam
check for a small piece logged inside, remove the toner cart and check that, take paper out and check under that
Jan 10, 2008 | HP Officejet 6310 All-In-One InkJet...
150 people viewed this question
k24674
jasbo
jasbo
