Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Card says it's locked but i have moved the little switch and still it days card locked i need help!
    Novelist:
  • 82 Answers
Have you proove with a new card??? its possible that the card is faulty?!?!?!
Posted on Aug 05, 2010
My camera IXUS 100 IS card locked. How to open it.
That means that the little write protection switch on the SD card is moved to the LOCK position. You need to move it the other way, so that the camera can write on the card again.
Feb 28, 2011 | Canon Cameras
Cannot take pictures -- says memory card locked - please help asap
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Dec 25, 2010 | Cameras
Memory card is protected????
Move the slide switch on the side of the card.
Oct 06, 2009 | Nikon Coolpix 5700 Digital Camera
Card locked
On the card there is a little switch that you can move to lock or unlock the card. Move the switch to unlock the card. Hope this helps.
Please rate!
Cheers
Oct 04, 2009 | Cameras
Memory card locked
Take out the memory card look on the left hand side of it and it might say in little letters lock and theres a little thing that moves up and down and then move it up.
Sep 20, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Card lock, how do i fix it?
Take out the memory card look on the left hand side of it and it might say in little letters lock and there's a little thing that moves up and down and then move it up.
Jul 22, 2009 | Canon PowerShot A540 Digital Camera
Camera no longer working
Your memory card must have had the switch moved from locked to unlocked. To fix this, removed the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says locked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on. Try it and let me know if I can help more.
Feb 17, 2009 | Kodak EasyShare C330 Digital Camera
Hi, My memory card will not unlock...I have tried moving the switch on the side and when I re-insert to view my pics it still says "memory card error card locked". Could you please help me with this issue?...
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jan 17, 2009 | Canon PowerShot A560 Digital Camera
Card locked
when a card is locked you want to check little slider switch on card didn't get moved-remove card and move switch and try again-push little tab over first on battery door nad then over and up
Jun 27, 2008 | Canon PowerShot A560 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
