Question about Samsung AS18A6RB Air Conditioner
Water is leaking down the wall from the inner unit. How can i prevent it
  • 38 Answers
I think gas is not there or indoor filter are blocked or pipe drainage
Posted on Sep 02, 2010
Aqualisa aquastream - when I turn it on the water pours down the wall. When turned off no trickle or leaks.
Surely something is leaking. I am attaching a diagram of the parts inside the unit for your reference. See if you can access the parts to find out which one is leaking and replace the broken part.
Feb 16, 2014 | Home
WATER LEAKING FROM FREEZER TO LOWER PART OF UNIT
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Feb 28, 2013 | Whirlpool Refrigerators
My 5200 wall air conditions works fine but leaking water on lower left corner down my wall inside my house. Already cleared outside drain hole and is dripping but can't reach or see the inner drainage...
The outer drain hole is the only one that needed to be cleared. But, keep and eye on it, as there may be some floating debris in the drip pan. You said the unit is angled enough at the rear. So, I'm assume you have at least 1/4" to 1/2" downward tilt at the rear of the unit. If that's the case, for now, that's about all you can do. Unless you have a Wet/Dry Shop Vac. In which case you could **** the water out of the drip pan after removing the front panel of the unit. If you attempt this, be sure the Master ON/OFF switch on the unit is OFF and the unit is unplugged.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Kenmore Single Room Air Conditioner
Kenmore model#59675932402 Top part of fridge not cold it is running but not cold, and fridge has been leaking also
check for ice buildup in the freezer floor,if so then the drain hole for the defrost pan is plugged up and when it defrosts the water from this leaks down into the refrige,you need to remove rear inner wall panel inside freezer and take a small wire and rat out the drain hole under the evaporator coil that goes to the bottom of the unit
Jul 02, 2011 | Kenmore Refrigerators
The washing machine is leaking water from the bottom of the unit...
look in bottom part of machine are in side wall dirty with grease if so leaky centre pole if so not good news replace machine to costly to repair
if inner walls clear of grease check for loose hose and fittings
Jun 12, 2011 | Maytag MAT13MN Top Load Washer
Cold air leaks in around the unit while it is not running. How can I insulate the air intake so that this does not happen?
Is this unit tight against the wall?
Can it be pulled away from the wall, without too much difficulty?
You need to be sure the leak is outside of the flue pipe going thru the wall to the outside.--
Or is it leaking in thru the inside?
If the leakage is due to a gap between the flue pipe and the hole thru the wall, then attention needs to be given to the flashing, and the air tight seal at the outside of the penetration...
Was a metal collar installed-- TIGHTLY against the flue pipe?
How was the needed air space (for fire prevention) made between the HOT flue pipe, and the framing materials?-- Then outside of that, how was the gap insulated?- (Non burnable-- like fiberglass can be used-- but it all depends upon the outer and then inner METAL seal rings being tight.)
Tell us more about where you are feeling the drafts..
Mack B
Dec 28, 2010 | Williams 3003622 Ceramic Wall Mounted...
WATER LEAK INSIDE
It likely has a hiding drain tube built inside the rear wall itself.
There are many many different models also.
Try to see if you can see the drain hose near the Compressor, and blow into it to see if it clears.
A lot of fridges require a serviceman to remove inner panels, ect to clear the problem.
Also,it might be ice built up at the top freezer section,preventing any further draining during regular defrost cycles.
Mar 04, 2010 | Refrigerators
The freezer has water and ice leaking in the
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Wall a/c is leaking water down log wall and puddling on floor.
When you sealed the holes outside, you trapped the water inside. The unit is designed to let the water run to the bottom of the pan and then go out the holes outside. Try unplugging one of them and see if that fixes the problem. Hope this helps.
Jun 24, 2009 | Emerson Heating & Cooling
BF1620 leaking dishwasher leaking help.
hi,Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Aug 06, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Samsung AS18A6RB Air Conditioner Logo
129 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
