Question about Cozy (VCR502A-BM) Heater
I have a problem with a pyrox gas heater that keeps turning off after a couple of minutes
  • Cozy Master
  • 3,328 Answers
Check too see if pilot is clean and check air ports to pilot could be blocked
Posted on Aug 08, 2010
Does Vulcan Pyrox gas wall furnace have a filter? It seems to cycle on and off too often and the gas seems too high. Also it makes a bang when reigniting. How can I turn the gas down inside it?
get it serviced by a licenced gas fitter / plumber. Should be serviced every two years. Don't risk your life via carbon Monoxide poisoning get a licenced gas fitter /plumber to assess the unit.
Jul 12, 2015 | Vulcan Heating & Cooling
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
Pilot light keeps going out
pilot light keeps going out! more then likely its the thermal coupling doing this. if bad it shut all gas to heater for a safety measure. just shut power off, then turn gas off and replace it. then you should be ready to go. to relight heater hold down on gas vavle knob in the pilot position, hold down and light it at the coupling where gas comes out. when it is lit, continue to hold down for 60 seconds. release knob very slow. then if its lit, turn to the run position. if flme goes out, wait at least 5 minutes to expel the gas fumes and turn to pilot and try again. good-day !
Mar 31, 2012 | Water Heaters
I have a model HE424M 33Mj/h gas Pyrox Firestar gas heater. I have just cleaned it and now it does not start. The pilot light is ok as is the spark but as soon as I let go of the centre button tha whole...
The pilot light has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. It seems that your thermocouple is faulty and needs to be replaced if pilot light keeps going out.
Sep 22, 2010 | Heating & Cooling
Have a pyrox gas heater, it ignites ok, but as soon as I release the button it goes out.
Check the thermal couple it may be no good and has to be replaced
Aug 19, 2010 | Heating & Cooling
Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Jun 15, 2010 | Heating & Cooling
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Cozy (VCR502A-BM) Heater Logo
1,400 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
