Question about Cameras
I find that even in a reasonably well lit room my camera struggles to pick up a clear image and always appears to be a lot darker than in real life. I would assume that on automatic setting this shouldn't be the case. Is there a way to solve this problem?
  • LeSavant Aug 05, 2010
    What kind of camera?
    Are you shooting with or without flash enabled?
    Have you read your user manual about shooting in low light conditions?
    Does the camera take good pictures in daylight?
    Does the camera allow you to make "manual" settings?
  • 571 Answers
Try bigger ISO-setting (in a well lit room 400-600 and darker even 1600). Also try to fix the exposure according to the darker parts of the room.
Posted on Aug 07, 2010
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
My screen is very dim, my pictures turn out clear and light but i cant see anything on the screen, even stored pictures. I have to put my memory card into a different camera or upload my pictures to see...
This problem is only related with back light in lcd screen and has nothing to do with ccd imager chip as explained by previous expert.
LCD screen is not getting enough voltage to lit back light to show its image thus you get darker image.
I suspect back light circuit section at main board got physical damage due to drop of camera. Visual check by qualified camera tech is needed to fix it.
Aug 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Avaya Partner line always lit
If the line button is lit then something within the system has picked it up. If the phone is a multiline set, the line 1 light on the set that is using the line will show green. The line could also be held by either a cordless phone on the system or the voicemail system. The easiest way to clear the line (if the held set isn't apparent) would be to cycle down the power to the phone system for a moment. That will clear the line if its held by the voicemail
Jun 02, 2010 | Avaya Corded Phone avaparp18d
Flash will go off even if i have it turned off
select manual icon of the dial,then flash will not give u trouble.if u use auto,program,etc auto system makes flash pop up.
Mar 25, 2010 | Olympus EVOLT E-500 Digital Camera
White spots on images
Does the camer have a removable lens. Is it an SLR camera. If so, there probably is microscopic dust on your sensor, or you have some dead pixels on your sensor. If you can get to the sensor, you can easily clean it with a cleaning kit. The most effective way of cleaning is to blow it off with clean air. Be gentle. On an SLR it is necessary to lock the mirror up. Your instruction book will explain how to do that. For more suggestions, Google cleaning my camera sensor and you will get a lot of suggestions. :-)
Dec 30, 2009 | Olympus SP-500 UZ Digital Camera
Can't see me during night time even there's is light
Several factors determine onscreen size of a video image produced by a Webcam. The actual Webcam hardware may be limited to a maximum resolution. The percentage of your screen filled by a Webcam image will be a factor based on your desktop resolution and the maximum resolution of the Webcam image. A third factor impacting image size is available bandwidth Webcam software may also play a role in determining image size, but in most cases the software is only limited by the Webcam output. There are several ways to optimize your results to make sure you send a Webcam image viewable at the highest resolution acceptable to relatives on the other end, while also optimizing your system to maximize available screen real estate with inbound images from relatives.
Webcam hardware is often a big limiting factor in determining maximum image size. Most Webcams on the market today output a maximum 640x480 image, which easily fills a television screen. Any of the Webcams currently available from Logitech, Creative, Apple, D-Link or the numerous niche companies marketing Webcams will support 640x480, although some produce better results than others. If you have a Digital Video camera capable of doubling as a Webcam, you may get a 720x480 maximum image size. Apple's iSight camera and some of the higher end Logitech cameras using CCD instead of CMOS image sensors produce excellent images at 640x480 in well-lit rooms.
Knowing 640x480 is the maximum image size, don't expect incoming video to fill your screen if you have your resolution at 1024x768. The graphic below is shows the relative portion of a 1024x768 screen filled by a 640x480 image at 50% of actual size. If you want the incoming video to fill your screen, reset the resolution of your monitor to 640x480 to properly accommodate the incoming video feed. This assumes your relatives are capable of sending 640x480 video from their end. If their sending limitation is 320x240, the best you can hope for is a video filling 50% of your 640x480 screen.
Nov 23, 2008 | Logitech QuickCam Express Web Camera
Itt night quest 150
Not sure if this applies, but this is on the Morovision site: http://www.morovision.com/faqs.htm Because of the manufacturing processes, all night vision image tubes will have different cosmetics such as small spots or specs, photocathode coloring, or a chicken wire effect from the microchannel plate. Most cosmetics are only noticed during viewing in high light situations such as viewing with the daylight filter on in a lit room. Most cosmetic blemishes are not noticeable during normal nighttime operation but may still be seen to some degree in certain situations. These cosmetics in no way effect the performance of the image tube and do not decrease the ability to perform nighttime tasks.
Jul 11, 2008 | ITT Night Mariner 160 Monocular
Kodak easyshare C530
Hey neilhowie,
I would make sure that your subject is within the range of the flash which for wide angle shots is 8 feet, and for telephoto shots is 9 feet. Another suggestion is to make sure auto exposure has been achieved by holding the shutter button halfway down until the green light appears and then take the image. Another thing you could try is to increase the exposure compensation. Nighttime photographs are difficult no matter what camera you are using so make sure your mode is set to nighttime, and of course your flash coverage would be the same as mentioned above.
Sincerely,
Allan
Go Ahead. Use Us.
May 14, 2008 | Kodak EasyShare CX7430 Digital Camera
Canon Vizcam 1000 fading fast
Hello Pelota, Here is what is happening, most web cams are charge-coupled device CCD type image devices they work by caturing the image as it changes the charge along the surface of a capacitive matrix. Over time this matrix begins to break down. This is what you are experiencing. The cheaper the camera the faster the breakdown of the matrix. It can not be helped. The fact is as all of these digital cameras get older they will begin the dim and have poor color resolution due to the CCD matrix decaying. I hope this helps.
May 17, 2007 | Canon VIZCAM 1000 Webcam
Dimension of image change when displaying clear or dark image
Same problem Picked up this monitor about half a year ago, a Viewsonic A91f+, and have been having some issues for a while now concerning what appears to be shifting in the monitor image, but that is about the best I can describe it as. It is most noticable when a large dark area meets a light area, like text or window edges. This "shifting" only occurs on the right side of objects and seems to show most often after I switch resolutions more than a few times, usualy due to gaming. Ive also noticed it happening from running random programs that dont require resolution changing/flickers but this happens FAR less often. -photograph of the effect- As you can see, its pretty subtle on a darker background, but Ive had no luck carturing it on a light one. Anyone have any idea as to what is occuring on this monitor and how it could possibly be fixed? Possibly an issue with magnets? For a while, I did have a small headset hanging off the the monitor on the side that the images "shift" towards, but even taking those off and away havent fixed it. Currently the only fix I have found for this is to shut my monitor off for 5-30 minutes, depending on how bad the "shifting" is when I find a time break long enough to fix it.
Jan 12, 2006 | ViewSonic G790 19" CRT Monitor
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
