Question about Technics SL-PD7 5-Disc CD Changer
Upon power up, CD player door opens on its own, then rotates the changer, then closes. Then will not do anything, and will only turn off if the main power cord is unplugged.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Simply replace your CD mechanical rubber wheels, rubber wheels on the open / close motor
Posted on Aug 05, 2010
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
Mar 19, 2012 | 2008 Honda Odyssey EX-L
Cd was still player and I found the player with drawer half open and jammed. I can't get it to sync with correct rotation, enough rotation or fully close or fully open. I can force it and hear the gears...
Rea alligning cds is not hard, but not too easy,the best way is to remove the whole cd changer mechanism and allign it to either one point,while totally disconnected, fully open or fully closed. I mean, the rubber or gear mechanism.
The main point of reference is the nearest part driven by the main motor. For example decide to do it when fully open, arrange everything so as to allow the tray to be fully open.If you get everything right, rotate the motor manually and see if it closes the tray without jamming..If it gets fully in keep rotating the motor and see if it loads the disc.if it does, return the assembkly, the sensors and the cd computer will take over from there ...
Apr 12, 2017 | Sony CDP-C445 5-Disc CD Changer
SL-PD8 cd tray is opening and closing, nonstop.
I called panasonic and they told me to do a hard reset on the system it seems to have worked on mine. Hold the power button continually while you unplug and replug the unit.
Jul 26, 2009 | Technics SL-PD8 5-Disc CD Changer
Open, closes and rotates the cd compartment, endless...
If there's a disk left over inside, It's stuck in the drive hanger, and should be removed else the changer can't put it back in it's right slot. Open the machine and check for any CD's still inside.
If not, could be that the small sensore (to the left of the head assembly (just before the drve (upside down)) is dirty or messed up.
Try cleaning if.
Jan 17, 2009 | Technics SL-PD687 5-Disc CD Changer
STUCK Door
You will not get shocked if you stay away from the power supply, I have worked on several of these,the cd's are pilled up behind the door, remove the screws ,remove the cd's ,and hopefully you did not strip the cd turntable gear. You will know if you the gear is damaged, when you power the unit up after removing the cd's .the turn table assembly will rotate very jerky.or slow ,or It might not move at all..if so let me know i can help you with that..good luck
Nov 02, 2008 | Harman Kardon FL8350 5-Disc CD Changer
YAMAHA CD PLAYER WON'T PLAY
GG  My kids had a PlayStation 2 that did this and so did my AIWA 3 CD player.  The solution for the PlayStation was to remove the cover use alcohol and clean the lens of the laser reader.  They get dust on them and simply cannot read.  The AIWA required replacement of the laser which cost almost as much as the unit and didn't last 6 months.
Oct 17, 2007 | Yamaha CDC-565 5-Disc CD Changer
Moved CD changer with discs inside - won't "reset" / work
CD PLAYER WILL RESET BY ITS SELF WHEN MAINS SWITCH IS PUT ON, SOUNDS LIKE YOUR MECH IS JAMMED TRY TO FIGURE OUT WHICH GEAR UNLOADS THE PLAYER DRIVE AND ALSO UNLOAD MANUALLY
Mar 27, 2007 | Sony CDP-CX400 400-Disc CD Changer
Technics SL-PD7 5-Disc CD Changer Logo
114 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
