What are the print servers that support Panasonic kx flb801. I bought a D link DPR 1061, but turn out to be that it doesnt support panasonic.
  • 857 Answers
Linksys WPSM54G or PSUS4 print server
WILL work for you.
To set up follow the following steps:
Configure the print server.
step 1
For any operating system that has a web browser: The procedure is similar to other Linksys gear. I'll sketch it here.
(1) With the printer and print server both powered off, connect the printer to the USB jack on the print server, and connect your (wired) network to the Ethernet jack. Turn on the print server, then the printer. (This is when it autodetects the printer.)
(2) Press the Reset button for 3 seconds (using an unbent paper clip or the like). The print server will print a status page revealing its IP address, something like 192.168.1.108 (but look at it carefully).
(3) Using a computer on the network, go to http://192.168.1.108 or whatever the address was.
(4) Default user name is all blank; default password is admin. Follow the menus to change the password, and make a note of it.
(5) Set up the network configuration. Assign a fixed IP address (I'll use 192.168.1.232). Mask should be 255.255.255.0 and gateway should be 192.168.1.1 in most home networks. If unsure, go to a Windows command prompt and type ipconfig /all to see the values for your computer.
(6) If you're going to go wireless, make sure to also set up the wireless connection. If you have a 64-bit WEP system, like many older networks, then under security, make sure you choose 64-bit WEP, Shared Key, and type in the key (not the passphrase). Or do whatever is appropriate on your network.
(7) Save changes. To go wireless, disconnect power from the print server and disconnect the Ethernet cable. Power it back up and it should connect to your wireless network. Printing a status page, the same way as before, will tell you how it's working.
(From now on you will administer it at http://192.168.1.232, or whatever number you assigned, not the address it had originally.)
Step 2
Configure each client computer (Windows). (See Step 4 for Linux.)
These instructions are for Vista 32- and 64-bit, and Windows 7. XP is very similar. Note that you do NOT need to install any Linksys drivers.
(1) Control Panel, Printers.
(2) Right-click in a blank area of the window.
(3) Choose Run as Administrator, Add a printer.
(4) Add a local printer (not networked).
(5) Create port. Standard TCP/IP port.
(6) Give the address you chose earlier (I used 192.168.1.232). "Query the printer" will probably not work, but there's no harm in leaving it checked.
(7) Assuming the querying failed, choose "Generic Network Card".
(8) From the menu of printers, pick the one you have.
(9) Print a test page.
You're done!
Step 3
Client computer setup procedure for Ubuntu Linux:
(1) System, Administration, Printing.
(2) New printer.
(3) AppSocket/HP JetDirect.
(4) Host: 192.168.1.232 (or whatever number you assigned). Port number: 9100.
(5) Select your printer by make and model, and print a test page.
These instructions probably generalize to other UNIX-like operating systems.
Posted on Aug 05, 2010
CD.INASTAL
The following are the two links for Panasonic KX-FLB801 All-In-One Laser Printer Drivers
Panasonic Official Support XP
External Link Windows 7
Good Luck!
Hope this helps!
CreativeTECH
Feb 23, 2011 | Panasonic KX-FLB801 All-In-One Laser...
I need driver for installing my panasonic all in 1
Good Luck!
Hope this helps!
CreativeTECH
Jan 04, 2011 | Panasonic KX-FLB801 All-In-One Laser...
Driver xp
click this link to download the driver for your Panasonic KX FLB801.
http://www.easy-share.com/1910431796/Panasonic kx flb801.exe
May 29, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Need driver
can i get software of kx-flb802cx
Nov 10, 2008 | Panasonic KX-FLB801 All-In-One Laser...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
